Old 06-08-2021, 10:51 PM   #1
V8guy
V8guy's Avatar
Default 49 Mercury Trans Adpater
Is there an adapter available to put the small 4 bolt pattern trans to a 49 50 Merc 8 bolt housing-?
V8guy is offline   Reply With Quote
Old 06-08-2021, 11:34 PM   #2
Newc
Newc's Avatar
Default Re: 49 Mercury Trans Adpater
I believe the stock Ford stamped bellhousing will work with an 8BA eng. Trans pattern used up thru 65 or so. Newc
Old 06-09-2021, 04:38 AM   #3
HD
the 49-51 Ford stamped steel , late 51 Mercury cast iron or the 52-53 Ford and Mercury cast iron,will bolt to an 8BA block, make sure you get the correct starter plate for the bellhousing you are going to use
HD is offline   Reply With Quote
Old 06-09-2021, 09:25 AM   #4
rotorwrench
rotorwrench's Avatar
A lot depends on the clutch control system you want. Shoe box Fords and 52 thru 53 Fords & Mercury cars have the lever fulcrum type clutch actuator where the late 1951 Mercury cast iron bell has the rotating clutch control like early Fords that use an equalizer set up. The late 51 Merc set up is one year only but they are still out there. Getting one with the bottom cover pan can be difficult but all the cast iron bells used on the cars have the same bottom cover.
Old 06-09-2021, 12:09 PM   #5
oldford2
oldford2's Avatar
I have this sitting around for the taking if it is something that works.
John
oldford2 is offline   Reply With Quote
Old 06-09-2021, 03:06 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
John
That SIR....is a very kind & generous offer....PERIOD! And you're close, but NOT the one he needs in a '49 thru EARLY '51 Merc, because of the clutch pedal method of actuation. This is what he needs, and these things, even PICTURES of these things, are rare! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-10-2021, 10:20 AM   #7
Ol' Ron
Ol' Ron's Avatar
The beauty of the 8BA block is: Everything fits it. Thr bekk housing and starter plate you have now is in hi demand for the early fords.
Gramps
