Old 05-14-2021, 05:03 PM   #1
tudor 28
Default new rear hub bearing failure
Do new rear wheel bearings have a failure with the end plates(thrust plates).
While looking for new bearings for my Model A sleeved hubs(uses '36-'48 Ford bearing ?) it seems as though it's a failure problem with the thrust plates (not hardened) and not the rollers.
If you've replaced yours with no failure problems who was the supplier ?
Don't want to go 500 miles like some have and bearings fail.
tudor 28 is offline   Reply With Quote
Old 05-14-2021, 08:34 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: new rear hub bearing failure
Most often new means china. Find NOS or good used.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 05-14-2021, 09:35 PM   #3
tudor 28
My searches for NOS have not shown any thing yet. I'll find them.I know there out there.
Your right. No China bearings.
Old 05-14-2021, 10:33 PM   #4
koates
Even some German made bearings that I purchased new had soft end plates in the roller bearings. Always pays to check whatever brand you buy by touching the end plates with a fine file. You cant trust any particular brand these days. Ask THIRD GEN AUTO to send you some good new bearings. Regards, Kevin.
koates is offline   Reply With Quote
Old 05-15-2021, 08:56 AM   #5
russcc
Or check with Fred at South Side Obsolete.
Old 05-15-2021, 09:39 AM   #6
svmsr1044
I had the same rear hub bearing failure pattern with my 40 when using new aftermarket bearings. The problem was solved when I finally found some NOS Ford bearings. Let us know if you find a source of quality bearings.
svmsr1044 is offline   Reply With Quote
Old 05-15-2021, 10:56 AM   #7
GaryU.
GaryU.'s Avatar
Looking on the swap side it look's like tudor 28 got his replacements. Hope he let's us know the source. I have a good used set if someone needs a pair as well.
GaryU. is offline   Reply With Quote
