Old 04-21-2021, 02:54 PM   #1
rockfla
rockfla's Avatar
Default Fram oil supply line suggestions
Anyone have a suggestion on a source for an oil supply line for a Fram external oil filter canister? As you see the flare on the canister side broke and the hose is cracked and getting short for ware. All of my local sources can make me a more "modern" hose which is also bigger and is also $ 50.00. and I hope will fit under the bottom of the canister into the fitting??? I bit the bullet so I can at least drive my car in the interim BUT would like to get something more period correct looking!!!!
FYI One end (The block side) is 1/8" NPT the other (Canister side) is a #4 inverted flare and NOT 1/8" NPT
Old 04-22-2021, 09:04 AM   #2
markdtn
markdtn's Avatar
Default Re: Fram oil supply line suggestions
You could make it out of steel tubing (fuel line). Both ends are fixed so should be OK. It's short so tight bends are difficult would be the hardest part.
markdtn is offline   Reply With Quote
Old 04-22-2021, 09:34 AM   #3
Gary in La.
Gary in La.'s Avatar
It looks like a firewall mounted filter in which case you do not want rigid lines.
Gary in La. is offline   Reply With Quote
Old 04-22-2021, 11:51 AM   #4
cas3
I would use Aeroquip as it looks a little better than rubber hydraulic hose and crimped ends
Old 04-22-2021, 01:55 PM   #5
markdtn
markdtn's Avatar
OK I see that now. I agree.
Old 04-22-2021, 04:54 PM   #6
Bob C
Maybe Southside Obsolete??
Old 04-23-2021, 08:55 AM   #7
jimvette59
jimvette59's Avatar
Markdtn when making ridged lines you should make a coil with a few loops to take up any movement .
jimvette59 is offline   Reply With Quote
Old 04-23-2021, 09:17 AM   #8
rockfla
rockfla's Avatar
Thanks for the opinions, I think I'm gonna just delete it from the car as they aren't that effective anyway!!!
Old 04-23-2021, 10:49 AM   #9
JSeery
JSeery's Avatar
Disagree with "aren't that effective", but on the other hand, flatheads were driven for years without filters. If you change the oil often it should be fine.
Old 04-23-2021, 11:00 AM   #10
ford38v8
ford38v8's Avatar
I don't know where you got the information that they weren't that effective. Bypass filters actually are more effective than full flow filters for two reasons: First, they trap finer particulates than full flow, and second, full flow filters must pass oil unfiltered should the filter get clogged up, while a bypass filter can simply stop the flow.
Alan
Old 04-23-2021, 11:06 AM   #11
tubman
tubman's Avatar
I'll go a step further and say that the way the vast majority of these cars are used and maintained, a bypass filter is superior to a full flow filter.
Old 04-23-2021, 11:33 AM   #12
19Fordy
19Fordy's Avatar
Rockfla:
Since you already have the canister, use it by using 1/4 in. steel fuel line with a loop in it to absorb any vibration. A flathead engine is solidly mounted and doesn't "rock and roll" so as to create a problem. Or, use a filter that bolts to the head bolts/ studs. They are plentiful. Also, you could leave the filter canister you already have on the firewall but, install a rubber pad under it to absorb vibration. Those OEM filters do work well.
Another idea is to modify the Fram filter by adding a 3 hole base from an old Ford OEM canister. It would be easy to do if you have access to a welder.
Old 04-23-2021, 11:55 AM   #13
rockfla
rockfla's Avatar
Originally Posted by 19Fordy View Post
Rockfla:
Thanks for the info.......3 hole base???? I was thinking about see "IF" i could change the 90* elbow on the bottom to something more "friendly" and easier to find.....BUT I maybe look at the "coiling" of a "hard" line OR maybe trying to see since the "original" line/Look is not an option them maybe something out of a SS braided line.
Old 04-25-2021, 07:50 PM   #14
MGG
MGG's Avatar
I used 1/4 inch nickel/copper brake line from NAPA for my oil filter lines. They bend easily without kinking and are easy to use. I am not concerned with originality.
MGG is offline   Reply With Quote
Old 04-25-2021, 08:34 PM   #15
Holeshot
Agreed and aesthetically they look horrible. Just change the oil on a regular schedule and you will be fine.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 04-25-2021, 08:44 PM   #16
tubman
tubman's Avatar
Originally Posted by holeshot View Post
agreed and aesthetically they look horrible. Just change the oil on a regular schedule and you will be fine.
wrong!
Old 04-25-2021, 09:06 PM   #17
Holeshot
Originally Posted by tubman View Post
wrong!
It's not wrong! It's WRONG!!!
If you are going to do the angry pirate tubman, at least do it correctly.
Old 04-25-2021, 10:14 PM   #18
tubman
tubman's Avatar
I suggest you try posting the word "WRONG" in capital letters all by itself in a response. There is something in the forum software that won't allow you to do it.
Also, thank you for agreeing with me.
Old 04-25-2021, 10:40 PM   #19
Holeshot
WRONG
Old 04-27-2021, 03:24 AM   #20
Desoto291Hemi
Reminds me of Waylon,,,,,,,Wrong,,,,wronggg !
LoL
Tommy
Desoto291Hemi is offline   Reply With Quote
