Hi Guys, I need help. First time build. 36 roadster brake pedal hits frame when it returns. Don't think this is right. The brake arm only has a M3 on it. The clutch has 48-7520-A2. Are these the right arms? I sur would appreciate any hep you can give me. Thanks in advance
Greetings Everyone. JAS1949 do you have the toe board installed? The clutch and brake pedal stop their upward movement somewhere near/resting on the rubber bumpers mounted under the 1936 drivers side toe board on my car.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
#3 | |
Thanks Guys. No I dont have the toe board installed. Frame off restoration. Couldn't find any other number on brake ar. Bends slightly to left then goes straight. I'll try and post a picture tomorrow. Thanks for the info,
i have found that laying a straight edge across the flat number pad on the transmission will give you a fairly close example of where the floor boards will end up once installed. good for mock up stuff
Thanks David, I can only dream, that my 36 will look as good as yours. But I keep on plugging away.
I believe that the " M " on the brake pedal is from the pedal manufacturer, Moore Drop Forging.
1936 Ford Deluxe Phaeton - absolute perfection. Thanks David for sharing. |
| Thread Tools | |
| Display Modes | |
