Old 02-01-2021, 11:05 AM   #1
Bob/Kansas City
Bob/Kansas City's Avatar
Default I'm in deep doo-doo
If anyone has an old vintage clamp on style external thread repair tool that I can use to repair the 5/8" - 18 threads on a '29 rear axle shaft that they would sell please let me know.
Thanks
Bob/KC
Bob/Kansas City is offline   Reply With Quote
Old 02-01-2021, 11:12 AM   #2
sinbad339
sinbad339's Avatar
Default Re: I'm in deep doo-doo
Here's an alternative some have used...
https://fordbarn.com/forum/showthread.php?t=150569
"Our times are characterized by a perfection of means and a confusion of ends." - A. Einstein
sinbad339 is offline   Reply With Quote
Old 02-01-2021, 11:33 AM   #3
Bob/Kansas City
That's an excellent video and a great idea! I may have to resort to that if I can't repair the current threads.
Old 02-01-2021, 11:58 AM   #4
Patrick L.
Patrick L.'s Avatar
I'm not sure what kind of toll you're looking for, I'm confused which is kinda normal.
Have you tried chasing the threads with a die or thread file ?
Old 02-01-2021, 12:06 PM   #5
Bob/Kansas City
it looks like this but for fine threads.
Old 02-01-2021, 12:25 PM   #6
BeerInaBag
https://www.amazon.ca/OTC-7402-Unive...06091633&psc=1
BeerInaBag is offline   Reply With Quote
Old 02-01-2021, 12:29 PM   #7
Bob/Kansas City
that tool starts at 1/14" o.d. which is much too large. Model A axle is 5/8" But thanks for trying!
Old 02-01-2021, 12:46 PM   #8
1931 flamingo
1931 flamingo's Avatar
Don Turley, who is a member here and posts frequently had one for sale a while back if I remember correctly.
Paul in CT
Old 02-01-2021, 12:49 PM   #9
Bob C
Here is one that Don Turley has for sale. https://www.fordbarn.com/forum/showthread.php?t=284050
Old 02-01-2021, 12:50 PM   #10
redmodelt
redmodelt's Avatar
If the threads just need clean up, get a thread cleaning file.
Old 02-01-2021, 12:58 PM   #11
McMimmcs
McMimmcs's Avatar
You can’t go wrong buying from Don Turley!
Old 02-01-2021, 01:04 PM   #12
Bob C
There are also split repair dies. https://www.threadtoolsupply.com/mur...air-58-18.html
File Type: jpg Screen Shot 2021-02-01 at 10.02.06 AM.jpg (13.0 KB, 13 views)
Old 02-01-2021, 03:05 PM   #13
Bob/Kansas City
Thank you ! This is exactly what I'm looking for. I've messaged Don Turley to see if he still has one available.
Old 02-01-2021, 03:24 PM   #14
Jacksonlll
Jacksonlll's Avatar
Make sure the problem is not with the nut. Try a new one.
Old 02-01-2021, 06:11 PM   #15
Slowmotoring
Slowmotoring's Avatar
Just curious why it has to be a clamp on style or split die? A “normal” die wont work?
Slowmotoring is offline   Reply With Quote
Old 02-01-2021, 06:45 PM   #16
Bob C
Usually the damage is at the end of the axle so you need to start
near the hub where the threads are good and work towards the
damaged area.
Old 02-01-2021, 07:29 PM   #17
Bud
Bud's Avatar
Just a thought: I had to fix one myself, so I took an old axle nut and sawed it in half, then clamped it to the axle threads with a vice grip and backed it off the axle. Naturally one should clean up any burrs on the nut after sawing. The nut is hard enough to force the thread form back in shape. If it gets to a point where it is hard to turn, take the two-part nut off, clean everything up and start again. This might save you the cost of a rethreading tool.
Bud is offline   Reply With Quote
Old 02-01-2021, 07:53 PM   #18
nkaminar
nkaminar's Avatar
I did much the same as Bud to repair my threads on my axle but I bought a grade 8 nut from Tractor Supply and sawed it in half using a Dremel cut off wheel. The nut actually cut threads. I did not debur the inside of the nut so it was nice and sharp.
Old 02-01-2021, 08:34 PM   #19
Tim Ayers
I have that tool that I got from Don. You are welcome to borrow it. Should fit in a USPO flat rate envelope so shipping to and from should be under $20.
Send me a message if you'd like to borrow the tool. I won't be able to get it out to you until Wednesday at the earliest. We've gotten hammered with snow.
Can't go wrong with getting one from Don as well. Great tool to have and it will save your hide in jams like this.
Found this thread. Kind of coincidental
https://www.fordbarn.com/forum/showthread.php?t=150569
Old 02-01-2021, 08:39 PM   #20
redmodelt
redmodelt's Avatar
The other clamp on repair tools shown above work the same way, from the inside out.
