Old 04-23-2011, 10:16 PM   #1
29FordGuy
29FordGuy's Avatar
Default Sticking float valve
Twice now my float valve has stuck open and when I turn on the gas it pours out the carborator intake. It is usually after sitting for awhile and no, I do not run the carborator dry when I park it. I did do that the first time it stuck so now do not. As I remember I have a pin seat float valve. Is the two ball gross jet style better and less prone to sticking? Thanks for help.
29FordGuy is offline   Reply With Quote
Old 04-23-2011, 10:30 PM   #2
TinCup
TinCup's Avatar
Default Re: Sticking float valve
The gross style is better but even it will fail if you have debris in the gas tank. I have used them all and still prefer the Viton tipped float valves. Now I know everyone will chime in about ethanol but I have used the same one for the last 3 years with no troubles. The new valves are specifically made to account for the ethanol fuels.
TinCup is offline   Reply With Quote
