Old 01-29-2021, 04:12 AM   #1
cdgray899
Default 1955 4door reverse lights?
Anyone had any luck with a decent reverse light setup? Mine only has metal caps where I assume they could go.
cdgray899 is offline   Reply With Quote
Old 01-29-2021, 08:27 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 1955 4door reverse lights?
FORD issued a dealer install kit for your situation. If no one else here has the PN (NOS), I will dig for it.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 01-29-2021, 09:09 AM   #3
Hot Rod Reverend
Hot Rod Reverend's Avatar
Default Re: 1955 4door reverse lights?
check this out...
https://www.hotrodreverend.com/post/...-backup-lights
maybe it will help - not sure what transmission you have and all but the back up lights are a pretty straight forward setup
Red Lion, Pennsylvania
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 01-29-2021, 05:18 PM   #4
down-the-road
down-the-road's Avatar
Has anyone tried this kit?
https://www.autokrafters.com/p-23256...5a-15499a.aspx
The listing identifies the Ford number as B5A-15499A.
down-the-road is online now   Reply With Quote
Old 01-29-2021, 05:39 PM   #5
KULTULZ
KULTULZ's Avatar
That is the original kit if in a FORD box.
Old 02-01-2021, 08:39 PM   #6
mercman from oz
mercman from oz's Avatar
1955 Ford Accessory Reverse Light Kit.
Old 02-03-2021, 11:27 PM   #7
cdgray899
Thanks to all that replied, this is super helpfil. Navigating the restoration has been an interesting process to say the least haha
Old 02-03-2021, 11:30 PM   #8
cdgray899
3 speed manual sitting behind a base 2bbl 272. I've been looking to get my hands on a 3 speed OD transmission and do a swap, though.
Old 02-25-2021, 02:58 PM   #9
pistonbroke
cdgray899, You will love your stock OD. Two things to remember. Change the rear end to match Normal is around 3.89 to 1 . The other is hook up all the controls! the passing gear is awesome with a Y block and dual pipes. Did tis on my 55 vicky and my 55 bird.
Old 02-25-2021, 04:05 PM   #10
Lamar Wadsworth
Lamar Wadsworth's Avatar
The '55 style backup lights were a dealer installed option. Also used on '56 except Fairlane and Third models. I like the'56 style better and have them on my'55.
Lamar Wadsworth is offline   Reply With Quote
Old 03-02-2021, 09:01 AM   #11
Cecil/WV
Cecil/WV's Avatar
I installed an OD in my '55 Ford in '56, never changed the rear at all and ran it for 8 yrs with great satisfaction.
Cecil/WV is offline   Reply With Quote
Old 03-06-2021, 11:42 AM   #12
scicala
scicala's Avatar
Where is the switch ? Shouldn't that be part of a kit too ?
Sal
scicala is offline   Reply With Quote
Old 03-06-2021, 03:46 PM   #13
wellcraft17
It takes two kits, the 1956 numbers are FDH-15582~C which is the parts that bolt to the steering column and FDR-15499-A and that is the tail light kit.
wellcraft17 is offline   Reply With Quote
Old 03-06-2021, 08:16 PM   #14
Lamar Wadsworth
Is the switch and hardware to attach it to the column the same for a 3 on the tree or Fordomatic? Right now I have mine wired up on a toggle switch under the dash.
Old 03-07-2021, 04:44 AM   #15
KULTULZ
KULTULZ's Avatar
Question Re: 1955 4door reverse lights?
Just wondering ...
Where did you source those PN's?
Old 03-07-2021, 10:32 AM   #16
wellcraft17
I have the original installation instructions that came with the kits I purchased and used on my 55 ford custom line. The instruction sheet was produced by the ford engineering group in Dearborn and dated 6- 15- 55.
Old 03-07-2021, 01:44 PM   #17
KULTULZ
KULTULZ's Avatar
Exclamation Re: 1955 4door reverse lights?
... hmmpf ...
Now let me ask you a question. Is it possible to scan the sheet and post it here? I think I have a copy but I will never find it.
Old 03-07-2021, 03:03 PM   #18
wellcraft17
Send me your contact number and I’ll send it to you
Old 03-07-2021, 04:08 PM   #19
wellcraft17
Kultulz, I don’t have any idea how to post the picture, send me your email and I’ll send it to you
Old 03-07-2021, 06:07 PM   #20
KULTULZ
KULTULZ's Avatar
PM sent incl E-MAIL.
THANX
