The steering column sleeve on my 1939 Ford is cracked down near the steering box. Is this a major problem? Is there an easy fix short of removing the entire steering column. It grinds a little when you turn the wheel.
You may want to check out a Chassis parts book for the part your seeing as cracked. There is an upper bushing under the steering wheel, many replace with a bearing.
I think there is a slot and a clamp at the bottom on the steering column where it attaches to the steering box. Perhaps your clamp is missing? Terry,OH probably has indicated the source of your grinding sounds, the upper bushing made of rubber, Here is a link to a drawing of the steering column and other parts from Mac Van Pelts site, lots of great info and parts. http://www.vanpeltsales.com/FH_web/F...ar_1937-39.jpg
I'm not understanding this description, can you post a little more detail and maybe a photo?
I have seen 40 mast jackets broke off about 1 1/2 inches from the bottom and figured it was from collision damage. I didn't notice it until I removed the column as the broken piece was the exact length of the portion that slips over the steering box and the break was under the clamp. Seems odd but I have seen that. While I could have welded it up I just replaced the mast jacket as they are plentiful, I think 40-48 use the same one.
Only way to fix it is take it apart. It will be full of dirt and grease and if you dont clean it out good. Trying to weld it will turn into a bigger mess. Once its clean its easy to weld back together |
| Thread Tools | |
| Display Modes | |
