Old 01-09-2020, 01:17 PM   #21
Jack Shaft
Default Re: Engine Stand
The face of the pan rail carries the load better in my opinion,the bracket bolts flush to the rail..yes you guys are right,going to the top of the rail is convienient
Old 01-11-2020, 12:26 AM   #22
Russ/40
Russ/40's Avatar
Actually the two pan rail bolts are only intended to give support so the engine angle is solidly held in a vertical position. Those bolts are not threaded into the pan rail they are just pins through the bolt holes.
Old 03-18-2020, 05:53 AM   #23
Bruce of MN
Bruce of MN's Avatar
Here is my version, just using angle iron, pipe couplings, and bolts. I wish I had greased the rotating part of the stand after it sat for 9+ years.
I think that it could be simplified by bolting the pan rail angle directly to the plate and have the water outlet bolts with spacers go through the lower arms, with the arms bolted on the backside of the plate, if needed.
Old 03-18-2020, 07:56 AM   #24
john in illinois
john in illinois's Avatar
I use Snyders adapter and a 4 WHEEL STAND-as mentioned ,very important.
I have had the long block plus clutch and transmission on the stand and never a problem
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 03-18-2020, 06:18 PM   #25
Bruce of MN
My last comment is pretty much like the post#6 pix.
