Old 09-18-2019, 06:25 PM   #1
alexiskai
alexiskai's Avatar
Default Re: Revise 7-tooth steering
Since the horn rod has to go all the way through the bottom of the lower bearing, the gear oil inside the steering box can leak out that hole. The tube goes up into the cylindrical gap between the horn rod and the inside of the steering shaft, and it's long enough that its end is above the level where the gear oil filling hole is.
