#21 | |
https://www.ebay.com/itm/Brake-Maste...sAAOSwtVdbliit |
#22 |
Good posts; I found that the '62/3 Cadillac dual drum/drum used the same large brake tubing as the '39/48 Ford. worked for me. Newc
#23 |
#24 |
Going out on a limb, that's how I will plumb mine. I have a couple AMC guys I can check with this week.
#25 | |
Actually, the size of the pistons doesn't matter, as the system is filled with fluid to begin with, and piston travel is very small. The need for a large reservoir is because disc brakes have no adjustment for wear. As the pads wear, the piston extends further out, but does not retract. So fluid level in the master cylinder goes down. With a small reservoir, the master may go empty before the pads are fully worn (if no one tops it off in the meantime). |
#26 |
#27 | |
Piston size does mater, and is why disc/drum and most drum/drum masters are not 50/50 in fluid displacement output. The different primary/secondary port fitting sizes prevent the front and rear OE circuits from being switched. You are correct that caliper pad wear is one reason the disc reservoir is larger than the drum. |
#28 |
Can you post a link of drum/drum master that has built in residuals?
#29 |
my 89 diesel dodge has the big tank to the rear, near the flange, and the small tank to the front, which is feeding the rear drum brakes. i know this because it leaks on a rear wheel cyl. need to fill every 3 months, gonna get to it one of these days
#30 | |
Drum/drum and (drum circuit) disc/drum masters had factory internal residuals up to the early to mid '70s, but that's no guarantee today's rebuilds have them installed. Easy to check at the parts store.
#31 |
So there is a chance the one I got doesnt have the residual valves. How do you tell ?
Mine was made in China for dorman products. Both ports on this one is 1/2" fine thread. |
#32 | |
GENTLY inserting a small diameter object will detect an internal residual, which is a small spring loaded rubber check valve. You may have a "generic" master because the OE AMC would have two port thread sizes, not one. 640 × 410Images may be subject to copyright. Learn More |
#33 |
I can stick a piece of TIG wire clear to the centerline of the casting. I assume there is not residuals in mine. If any doubt, I would run 2lb residual valves, one for each wheel cylinder, correct?
#34 | |
Run one external 10 lb valve close to the master cylinder for each drum axle if none are internal. The 2 lb valve is strictly aftermarket and should only be used for disc axles when the master is below the floor or lower than the calipers. |
#35 |
Aw, yes i had the 2lb and 10lb valves switched in my head. Thanks for the clarification Bob.
#36 |
#37 | |
"Came too close to dying to stop living now!" |
#38 |
I checked the Dorman master cylinder that I have and it does not have the residual valve.
The original single circuit 40 ford master cylinder has a check valve in the base of the bore. Does that serve the same purpose of a residual valve? |
#39 |
#40 | |
To me the most alarming thing happening today, is these drum drum vehicles are being used with MC with different size reservoirs and no residual pressure valves. Typically a large/small reservoir on a MC means it is disc/drum. When you see a large reservoir you can count out a residual valve and even the opening for fluid flow will probably be larger. You loose some engineered brake bias.
Pete's Ponies Mustang RUSToration & Performance |
| Thread Tools | |
| Display Modes | |
