#21 | |
I ask "If air cleaners are so useless, why does every modern car have one??"Same with oil filter. I agree that the wiere mesh type air "stainer" is near useless. I run a paper element filter mounted on the radiator stays and wouldn't consider going without one. It is very difficult to install any air filter because of the steering column. Very poor design.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#22 |
Like Ernie, I also use the K&N filter and I drilled a couple of very small holes in the bottom in case gas filled up in there.
#23 |
Most any wire mesh will stop a flame in it's TRACKS!
Bill Safe
#24 |
Coat the wire mess by soaking it in oil and letting it drip, then install it. Oil traps and holds the dirt until you rinse it out in kerosene.
#25 |
Got a picture to share? And/or a part #?
#26 |
#27 |
Here is a photo of the K&N I use on an original air maze.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 08-28-2018 at 02:59 PM. Reason: Added photo of air filter w/Air Maze on engine |
#28 |
I don't run a filter, the roads are cleaner today than they were in the 20s
#29 |
i have the exact setup as 160.
#30 |
Thoise things are as useless as flyscreens for a submarine. They CANNOT be fitted here. The steering column is in the way and I'd prefer steering!
#31 | |
And yes this is not suitable for a RH drive Model A due to the steering box interference.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 08-28-2018 at 09:37 PM. Reason: added comment on screen and RH dr |
#32 |
Here are my K&N filters. RHD car so I fabricated right angle adaptors at full cross section out of sheet metal as shown in the third pic.
Some (most or Many???) say they are ugly. The oil filter certainly is. I think the more upturned one is cheekily cute! They catch a lot of dirt even on tarsealed roads. And I still get the same 22 to 24 mpg (larger imperial gallons) on a trip at 55 to 60 mph. SAJ IN UK at present PS I just noticed the glass filter bowl in the second pic is half full of water. I had a faulty tank cap, since fixed! Last edited by SAJ; 08-29-2018 at 05:46 AM. Reason: Added a PS |
#33 | |
Bill W.
#34 | |
![]() I usually have my engine pans on also. K&N I use. You will have to extend the Air Maze rod.https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ![]() If you use a WIX filter they don't show as much as they are painted black. Or paint your white one black or Ford green. Last edited by Y-Blockhead; 08-29-2018 at 09:48 AM. |
#35 |
Y-Blockhead, the ones like yours that point down are not as ugly either. I have not found the correct adaptor in NZ so far. Plus I am always in a hurry to fit a new filter and get going. I forget to paint them and wait for them to dry. Plus again a vertical one can be filled right up before running. I can only fill mine about 2/3 full before fitting.
Then again oil pressure registers within seconds of start up on a new filter on my gauge. When I get back to NZ I will make a concerted effort to find 2 right angle adaptors for my oil filters............maybe. SAJ in Cornwall UK |
#36 |
SAJ, I think vendors sell the adaptor you want. That said, I have grafted in right angled adaptors from other cars before today.
#37 |
I've seen Argentina cars, with home made plumbing & an Early Ford Oil Bath air cleaner, mounted at the right front of the engine
Bill W.
#38 |
It was tired of being teased by the other Model A's and ran away.
| Thread Tools | |
| Display Modes | |
