Old 02-02-2018, 06:52 PM   #21
40cpe
40cpe's Avatar
Default Re: Flaathead Ted brake kit install
I'm all ears! Waiting to hear about this possibility.
Old 02-03-2018, 11:11 AM   #22
'36 5W
'36 5W's Avatar
Ditto here!
'36 5W is offline   Reply With Quote
Old 02-03-2018, 12:42 PM   #23
Russ/40
Russ/40's Avatar
Originally Posted by FlatheadTed View Post
You mean like 39 hydraulics ,I have the prototypes but never went any further ,since the Lincolns are available ,Should I revive the development ,Ted
Absolutely go for it. I'd love to be the USA road test for a set. The Lincoln setup is just too expensive for a lot of us. My 40 would be my test case. I've been wanting to do something with the brakes for years. Come on Ted, you can do it!
Old 02-03-2018, 01:45 PM   #24
Jack E/NJ
Jack E/NJ's Avatar
Ted>>>I will see what I can do between doing steering boxes>>>
Thanks Ted!!! But how about doing steering boxes between doing Lockheed floaters instead? 8^) Jack E/NJ
Old 02-12-2018, 11:54 AM   #25
bmwillia
bmwillia's Avatar
Ted,
I have your kit installed and saw a little improvement, but nothing like you show in your videos.
I noticed you mentioned that the shoe material needs to be soft. Does that mean the woven fabric material?
Thanks,
Brad
Brad Williamson
bmwillia is offline   Reply With Quote
Old 02-12-2018, 12:20 PM   #26
jerry shook
I have Ted kit in 2 cars. The were a little hard to get adjusted i blame it on myself for not going by instruction. Now i would never have anything else they are great.
jerry shook is offline   Reply With Quote
Old 02-12-2018, 01:36 PM   #27
bmwillia
bmwillia's Avatar
Jerry,
What type of material is on your brake shoes?
Brad
Brad Williamson
Old 02-13-2018, 03:02 PM   #28
FlatheadTed
FlatheadTed's Avatar
Here's some lining # NA3923 woven .NA3812 grey soft bonded,not sure if theses numbers would mean much to you ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-13-2018, 03:48 PM   #29
Tim Ayers
I would be interested in a set for juice brakes as well.
Old 02-13-2018, 07:46 PM   #30
tub1
tub1's Avatar
I'm very interested in a set for hydraulics
tub1 is offline   Reply With Quote
Old 02-14-2018, 02:57 PM   #31
FlatheadTed
If anyone is confused about types of linnig to use try the Model A site on FB ,or search ,whats good for a A is good for a v8 ,Ted
Old 02-15-2018, 02:02 PM   #32
AnthonyG
AnthonyG's Avatar
Smile Re: Flaathead Ted brake kit install
Very cool & informative string.
Nomad
AnthonyG is offline   Reply With Quote
Old 02-15-2018, 09:30 PM   #33
Phil Gillespie
Phil Gillespie's Avatar
Ted it would seem that there is a lot of interest. For you to return to this project could make a lot of guys happy and safer stopping.
I include myself with the people who would like you to take up the task.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 02-15-2018, 09:43 PM   #34
AnthonyG
AnthonyG's Avatar
Ted, why are the brake linings we should use with the mechanical energizer kit such a mystery. Can you give us the correct mfg. and their part # & where to get? Your direction to the FB Model A site and the search "whats good for a A is good for a v8" didn't find anything?
Thx
Nomad
Old 02-16-2018, 05:09 PM   #35
1932tub
https://www.jalopyjournal.com/forum/...ersion.387348/
Check this out there is a heap of info on the Hamb on how to convert early Ford brakes to bendix operation
1932tub is offline   Reply With Quote
Old 02-16-2018, 06:43 PM   #36
Kpar
Kpar's Avatar
OK I pulled out the experimental backing plate ,I will see what I can do between doing steering boxes Ted
Ted you mentioned steering boxes. A bit of feed back my 33 is a different car after installing your box. Thankyou
Keith
Kpar is offline   Reply With Quote
Old 02-16-2018, 10:13 PM   #37
Jack E/NJ
Jack E/NJ's Avatar
Yep. I saw that awhile ago. That's precisely the reason why I asked Ted about doing *his* floaters on the *original* Ford Lockheed setup. Jack E/NJ
Old 02-16-2018, 10:17 PM   #38
Jack E/NJ
Jack E/NJ's Avatar
Keith
What does "different" mean? Thank you. Jack E/NJ
Old 02-17-2018, 08:23 PM   #39
FlatheadTed
I looked at the Ham and that's quite a involved fit up I am hoping to do something simpler than that Lincoln set up ,I will put these through the dealers if successful ,this may need to be in the winter for testing ,
Brake linings The lining numbers I have given are good to use but I don't know if these are USA numbers , I will look into it and report back .What's good for a Model A is good for a v8 ,any search on brakes on the A site will give some useful info. Ted
Old 02-20-2018, 03:10 PM   #40
FlatheadTed
Here's a picture of the linings previously mentioned ,These can be riveted or bonded ,Ted
