Old 07-09-2017, 08:11 PM   #1
leon bee
Default Piston Expanders?
Man, I never heard of this in my life. Since there's eight in a set I guess you installed them and ran with them? I'll see if I can link to ebay:
http://www.ebay.com/itm/Piston-Expan...53.m1438.l2649
leon bee is offline   Reply With Quote
Old 07-09-2017, 09:02 PM   #2
JSeery
JSeery's Avatar
Default Re: Piston Expanders?
Very interesting, never heard of such a product.
Old 07-09-2017, 09:12 PM   #3
leon bee
So far, looks like Google never heard of em either.
Old 07-09-2017, 09:13 PM   #4
40 Deluxe
Sounds like you two boys missed out on the good ol' days! These were a common item back in the day.
Old 07-09-2017, 09:13 PM   #5
JSeery
JSeery's Avatar
The instruction sheet is interesting as well! Perfect Circle no less.
Old 07-09-2017, 09:27 PM   #6
drolston
drolston's Avatar
Ranks up there with Motor Honey, Spark-O-Matic and Water Injectors.
Old 07-09-2017, 09:28 PM   #7
JSeery
JSeery's Avatar
Lean new stuff every day!!! https://docs.google.com/viewer?url=p.../US2341959.pdf
Old 07-09-2017, 11:18 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by JSeery View Post
Yep, just one of the tools that were available to install 'knurled' surfaces on the skirts of pistons to decrease the cylinder wall clearance.
Witnessed and participated in a number of engine 'overhauls' using this method.
Old 07-09-2017, 11:55 PM   #9
Curt in AZ
Curt in AZ's Avatar
Why does the description say "reproduction?"
Curt in AZ is offline   Reply With Quote
Old 07-10-2017, 01:02 AM   #10
flatheadmurre
flatheadmurre's Avatar
Lotīs of ways to "fix" things if labor was cheap.
Grinding pistons to undersize and reusing.
Piston ring regroover and steel shims.
Old 07-10-2017, 02:30 AM   #11
51 MERC-CT
51 MERC-CT's Avatar
Isn't that a question for the seller of the product?
Old 07-10-2017, 03:22 AM   #12
pooch
pooch's Avatar
I had pistons expanded by shot blasting back in the 70/s.
Was a normal everyday job then.
pooch is offline   Reply With Quote
Old 07-10-2017, 04:13 AM   #13
flatheadmurre
You canīt get material worn away back again so what you get after knurling is a piston with less lifespan then a new one.
Back when labour was cheap and lack of parts was an issue i can get "fixing" stuff.
Old 07-10-2017, 06:25 AM   #14
51 MERC-CT
51 MERC-CT's Avatar
Sure, when an engine is rebuilt new pistons are used but when it is overhauled, knurling the piston extends it's lifespan, at a lesser cost. Call it the cheapest way but that's what people wanted, and it worked.
Old 07-10-2017, 07:52 AM   #15
Pete F
Pete F's Avatar
Perfect Circle had a knurling attachment for the lathe to knurl the skirts that would work for a while but today the hot setup is have the skirts coated by Swain Tech .
They can build up the skirts a couple of thousands.
Pete F is offline   Reply With Quote
Old 07-10-2017, 08:07 AM   #16
flatford8
flatford8's Avatar
I had a '70 Triumph 500 in the early 80's that had knurled pistons. I took it apart for other reasons, but it ran fine. First time I had seen them.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 07-10-2017, 08:52 AM   #17
Bored&Stroked
Bored&Stroked's Avatar
There were lots of ways to do the cheapest possible service on an engine - to get it back on the road and in the process, spending the least amount of dollars. Dang near every small town had somebody who "rebuilt engines" . . . everything from lawn mowers, to tractors, to cars. People didn't have money to spend and there was a lot of cheap labor available (young 'blue collar' folks) - without XBoxes, Computer Games and Texting to distract that 'cheap labor'. LOL
Old 07-10-2017, 10:15 AM   #18
STEVE O
STEVE O's Avatar
I had a set of original Mopar piston expanders just like these for my 50 Plymouth but I didn't use them when I had the engine apart because the pistons still checked out very close to factory specs.
STEVE O is offline   Reply With Quote
Old 07-10-2017, 10:36 AM   #19
woodiewagon46
I have heard of knurling a piston to decrease the slop but these things I have never seen. So if I read it correctly, they actually expanded the piston, did these thing really work?
woodiewagon46 is offline   Reply With Quote
Old 07-10-2017, 11:09 AM   #20
leon bee
I also knew about knurling, and have seen the little tooling parts for it. Then it looks like there was a setup for expanding pistons before you put them in. But these deals are a whole new idea for me.
