No not that one, this one. Anyone have any idea how old this is,it definitely looks old.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
If I read the tire correctly it is 6.00 x 16, which is correct for a '41. Judging from the color of the wheel, the color of your '41, and the small hubcap center, I would say that wheel is 76 years old! It could be as old as 1936, or as new as 1948.
That is a very old Tyre that shows the Good-Year Flag. |
If it has no date code, I'd figure a guess later 50s or early 60s on the tire. The smooth steel wheels came on the scene in 1940 for Ford. 1936 through 1939 were all wide five.
What would the date code look like if it had one?
https://corporate.goodyear.com/en-US...corporate.html |
I have no idea. They may not have required date codes when that tire was manufactured. I notice is has a "made in Canada" on the side wall. The other number on the side wall besides the size of the tire may be a part or style number. It doesn't look like any sort of date code. Modern date codes are four digit and have the first numbers as the week of manufacture and the second set of numbers is the last two digits for the year of manufacture.
I emailed Goodyear, we will see what they say. Here's the kicker, my car is a Canadian Ford...makes you wonder ,could it be original?
Here is a picture of the tread.
The ad in the link below states that the "diamond tread" was available '32-'48...........? Maybe so, or maybe no! No doubt about it...that IS a '40 or '41 4"-wide wheel, obvious by the shape of the stampings around each lug hole. DD
https://www.universaltire.com/goodye...blackwall.html
Looks to be a good one to clean up and put on display.
tony-starr.com |
If it doesn't have a DOT date code on the tire DO NOT USE IT!
The sign of a good craftsman is how well they cover up their mistakes. |
#13 |
Here is mine it was in the trunk, has the Ford script, looks to be original, I'm not going to drive on the 76 y.o. Tire
#14 |
Goodyear started making the Eagle all weather tires somewhere around 1949. This link from the UK shows adds for them up to 1953 but I think they made them a lot longer than that. They made the Goodyear Eagle motor cycle tires clear up to the late 1970s. My first HD big twin came with them. They were scary tires too. I like the modern compound tires a lot better.
http://www.gracesguide.co.uk/Goodyea..._and_Rubber_Co |
#15 |
I emailed Goodyear and they forwarded it to the University of Akron(they have Goodyear's archives) and this is the response I recieved.
We got it. The images came through fine and we’ve started going through the Goodyear material. Early indications are that brand of tire was manufactured in the 1930s and 1940s. We don’t have much information on the Canadian manufacturing operations but we may get lucky. Hope to get back to you sometime next week with an update. www.jalopyjournal.net John
| Thread Tools | |
| Display Modes | |
