Old 08-25-2016, 12:54 PM   #1
flatjack9
flatjack9's Avatar
Default 36 roadster floor mat
Finally getting around to putting my roadster back together. I see Drake sells a black floor mat. The 36 Resto book calls for a gray mat. Are these available anywhere or do I go with black? Thanks, Jack.
Old 08-25-2016, 01:23 PM   #2
rockfla
rockfla's Avatar
Default Re: 36 roadster floor mat
Seems to me this discussion of "Mat color" came up recently in a post but for a different year...if I recall correctly someone in the post said they Spray painted the black mat the correct color with an interior paint? Might have been on a 1932 post within the last week or so??? Might try a search!!!!
Old 08-25-2016, 01:54 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I am assuming you are talking about the front floor mat and not the rear rumble seat floor mat? Check to see what Carpenter has to offer now in his catalog or on his website. I don't recall the colors that were mentioned in the book, but I didn't think it was gray. Maybe taupe? But that might be for closed cars. CRS.
John
Old 08-25-2016, 02:02 PM   #4
rockfla
rockfla's Avatar
It was an Aug 4th post on 37 Floor Picture.....Dave Rehor posted about how he fixed original floor mats and used SEM paint for the correct color. Search 37 floor picture
Old 08-25-2016, 02:04 PM   #5
weemark
The only colours I've seen are black and taupe, never seen a grey mat.
weemark is offline   Reply With Quote
Old 08-25-2016, 02:22 PM   #6
DavidG
DavidG's Avatar
Starting in the '36 model year, the mat color was Benton Gray. It is as much brown as it is gray. The '32-'35 mat color was taupe.
Old 08-25-2016, 02:23 PM   #7
JoeGermann
JoeGermann's Avatar
I have an unrestored 36 Cabriolet with 7548 original miles and the floor mat is black.
JoeGermann is offline   Reply With Quote
Old 08-25-2016, 03:40 PM   #8
rockfla
rockfla's Avatar
@ JoeGerman
Not stirring the pot or trying to start anything BUT the Zen Master has spoke in post #6. I would say your car may be unrestored but as the stated color in post #6 by Dave, I would say your mat was replaced at some point with the wrong mat IMO.
Old 08-25-2016, 09:06 PM   #9
flatjack9
flatjack9's Avatar
According to the 35/36 resto book, early 36's had a taupe mat as did the 35. Very early on, it was changed to Benton Gray.. Carpenter has a taupe floormat which I ordered. Curiously, the rear roadster mats are Benton Gray. I figure if I need to change the color of the mat, it will be easier to do it with a taupe mat, rather than a black one. Thanks for the insights.
Old 08-26-2016, 06:58 AM   #10
DavidG
DavidG's Avatar
I understand that the current Carpenter '36 front mat is incorrect in another and in many respects far more important way than any color issue. They come with the various holes for the hand brake, starter button, etc., but the big one for the transmission shift lever housing is in the wrong location. It is located for the shift lever housing of a '35, which of course is further rearward than that of the '36.
Old 08-26-2016, 12:21 PM   #11
flatjack9
flatjack9's Avatar
Is the shifter location proper in the black Drake mat?
Old 08-26-2016, 07:25 PM   #12
Brad Boyer
Benton Gray is the way to go...Carpenter has... The Drake is taupe and did not match my 36 5 window Deluxe...
Brad Boyer is offline   Reply With Quote
Old 08-26-2016, 08:39 PM   #13
flatjack9
flatjack9's Avatar
Carpenter only showed taupe. Drake listed as black in new catalog.
Old 08-26-2016, 09:20 PM   #14
Capt Kirk
Capt Kirk's Avatar
My 35 Cab is Taupe and it all fit well with the exception of the long ago change hydraulic brake pedal.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 08-26-2016, 10:07 PM   #15
restoman
Hi Dave, I have known for many years of your expertise on 32's but only recently looking at F B have I become aware of your detailed knowledge of all the early V8's. Quite amazing and thanks for sharing all of it with the rest of us. PHIL SPAID
restoman is offline   Reply With Quote
Old 08-27-2016, 08:12 AM   #16
flatheadfan
flatheadfan's Avatar
One of the BIG problems with a rubber mat is the likelihood of it tearing especially when checking the battery. Interesting, in Canada they had a 1936 "special deluxe" which had factory carpeting.
Tom
flatheadfan is offline   Reply With Quote
Old 08-29-2016, 02:42 PM   #17
gnolnor
gnolnor's Avatar
I purchased a front and rumble area Taupe rubber matts from Dennis Carpenter
less than a month ago. It even had insulation carpet on the underside. Made with new molds and the edges are very distinct! Ron Long (gnolnor)
gnolnor is offline   Reply With Quote
Old 08-29-2016, 05:46 PM   #18
Ball and Chain
Ball and Chain's Avatar
Anyone know if you can use a 39 mat in a 35 if it has juice brake pedals and 39+ trans?
Throttle Benders
Est. 1949
Ball and Chain is offline   Reply With Quote
Old 09-13-2016, 09:23 AM   #19
V8ER
'36 front floor mat update: C & G has the correct front floor mat for '36. I bought two benton gray mats, which arrived yesterday. They fit well. The C & G web site says they have them in stock in both benton gray and taupe.
V8ER is offline   Reply With Quote
Old 09-15-2016, 06:56 AM   #20
37 Cab
37 Cab's Avatar
I bought the mat for my 37 Cabriolet from C&G. It fit very well except for the brake pedal. (40 brakes) They said they do not have a rear (behind seat) or rumble seat mat available. I used the old front mat in pieces for the rear section but still have no rumble seat mat.
Tommy
37 Cab is offline   Reply With Quote
