Old 04-05-2016, 08:31 AM   #1
reagen
Default 1935-6 ford headliner 5 window
Hi everyone ,does anyone have a old headliner for a 5 window to borrow on sell i need to make a pattern thanks for reading either way. Reagen
reagen is offline   Reply With Quote
Old 04-06-2016, 03:56 PM   #2
Matt in Alameda
Default Re: 1935-6 ford headliner 5 window
Early 1935 headliners are different than late '35. '36 is the same as late '35. You will save yourself a lot of frustration and time if you just contact Le Baron Bonney or Cartouche, they will cut it, stitch it and it will fit as originally made. Good luck,......Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 04-06-2016, 08:21 PM   #3
FlatheadTed
FlatheadTed's Avatar
Early 35 with card rear panels .Get a bit of HL cloth wider than what's needed ,sow across at the width of your upper wood bows in two lines include a folded piece of calico 1,1/2 wide to tack through .Start at the back work to the front keep it loose or just firm .after doing the header stretch it from side to side tacking as you go to the back ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-07-2016, 06:19 AM   #4
reagen
Thank you for your help . Reagen
Old 04-07-2016, 02:18 PM   #5
FlatheadTed
Another way is to tack first at the rear wood bow with just a few tacks ,then lightly pull it back to the rear and tack over the rear window ,then finish at the rear wood bow (reposition if needed ),then tack at the front wood bow , work your way forward to the header .then start to tack over the doors .The stretching is done mainly from side to side .You use a soft piping (Hide am ) along the sides .Then Cut out the light ,It looks much more difficult than it is .Ted
Old 04-07-2016, 08:17 PM   #6
FlatheadTed
Just add to what I said there is a total of three seams ,don't use the front light bow but the one between the light bow and header , The rear cross bow you thread through the loop of calico sown 10" back from the first light bow . Ted
Old 04-09-2016, 08:58 AM   #7
reagen
Thank you it all helps so much !!
Old 02-03-2023, 01:06 PM   #8
HenryCarl
I'm getting ready for spring. I have material for a headliner and I've noted in a google search that a headliner maker will use the material I already have from an overstock in someone's garage...right fabric. But I've read here that there's a difference between early '35 and later '35. How to make that determination? Thank you.
HenryCarl is offline   Reply With Quote
Old 02-03-2023, 08:03 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
There may be some information on this in the Early Ford V-8 Clubs 1935 to 36 Ford Book, not sure, but if not, Don Rogers may have something on this in his personal files.
John
Old 02-04-2023, 01:50 AM   #10
rich b
rich b's Avatar
Couple pictures of an early headliner and rigid panels around the back along with a couple of late headliner which extends to the back window.
Old 02-05-2023, 05:35 PM   #11
HenryCarl
Thank you for the pics with the difference between early and late headliners. I'll also check Don's book. And, by coincidence, he lives here in St. Louis and is a member of the local EFV8 club.
Old 02-10-2023, 09:28 AM   #12
reagen
I put my headliner in my self not really hard at all and still have to finsh it lol
