Old 02-23-2016, 12:03 PM   #1
jerdan
jerdan's Avatar
Default Fuel pump
I am looking to change my 53 flathead v/8 to an electric pump. What do you suggest and what do I look out for. Do I go thru the mechanical pump or remove it? What about the pushrods?
jerdan is offline   Reply With Quote
Old 02-23-2016, 12:09 PM   #2
JSeery
JSeery's Avatar
Default Re: Fuel pump
Sorta up to you. If you do go through the mech. pump you need to modify it so a failure won't pump fuel into the block. You can leave the rod in.
Old 02-23-2016, 12:38 PM   #3
Joe Immler
I installed an Airtex fuel pump, Part No. E8902. Installed it close to the fuel tank. I only use as necessary and left the mechanical as is.
Joe Immler is offline   Reply With Quote
Old 02-23-2016, 12:44 PM   #4
Vic Piano
Vic Piano's Avatar
I have done this to a number of our antique vehicles, both 6 and 12 volt, Ford and non Ford. As mentioned previously, I modify the OEM fuel pump, making it a pass through (I detailed the modification on my thread "What I did on my Lunch Hour") and I leave the pushrod in. This way the Airtex pump and fuel pressure regulator (set at 2.5 lbs.) become the full time fuel delivery system.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 02-23-2016, 12:45 PM   #5
19Fordy
19Fordy's Avatar
The "search" function is your friend. This has been discussed many times. Read here:
http://www.fordbarn.com/forum/search...archid=6505852
Old 02-23-2016, 02:03 PM   #6
Lawson Cox
Lawson Cox's Avatar
Damn Vic, it would take months to search through your "What I did on my lunch hour" epistle. LOL
Old 02-23-2016, 03:45 PM   #7
Vic Piano
Vic Piano's Avatar
C'mon Lawson, what else have you got to do??? LOL
Old 02-23-2016, 06:08 PM   #8
39topless
If you mount your electric pump to the cross member, I would suggest that you insulate the mounting bracket on the pump from the metal of the cross member with some sort of a hard rubber pad or washer. Much quieter!
39topless is offline   Reply With Quote
Old 02-23-2016, 07:12 PM   #9
Bill S
I mounted mine on the frame rail. Can not hear it run in the car. It's an Airtex.
Bill S is offline   Reply With Quote
Old 02-23-2016, 09:35 PM   #10
El Rat
I mounted mine between the crossmember and fuel tank complete with regulator and liquid filled gauge. Pumped thru the stock pump. I use a three way toggle to energize the pump. In one position the electric only works when I hit the start button, one position is full on and one is off!
El Rat is offline   Reply With Quote
Old 02-23-2016, 10:05 PM   #11
Pete
As noted on another thread, don't forget an inertia switch.
Old 02-24-2016, 10:17 AM   #12
flathead47
flathead47's Avatar
For those interested Vic's fuel pump modification starts on page 78 , line 1543
flathead47 is offline   Reply With Quote
