Old 12-06-2010, 11:50 AM   #1
Rbolt
Default Frame?Can you Date a Frame By Vin#
New to the model a was wondering
Rbolt is offline   Reply With Quote
Old 12-06-2010, 11:58 AM   #2
IrishHills
IrishHills's Avatar
Default Re: Frame?Can you Date a Frame By Vin#
I'm new to Model A's too, but think originally it was same as motor number..
http://www.modelahouse.com/cgi-bin/enumbers/numdate
IrishHills is offline   Reply With Quote
Old 12-06-2010, 11:58 AM   #3
31Tudor
31Tudor's Avatar
The frame was stamped with the engine number as the engine was put into the frame. So...the frame number should coincide with the same engine numbering month and date from the engine number charts.
31Tudor is offline   Reply With Quote
Old 12-06-2010, 12:04 PM   #4
Rbolt
That maks it Tricky i do not have the original eng
Old 12-06-2010, 12:05 PM   #5
MCHinson
MCHinson's Avatar
If you have the frame number, you have the original engine number. The engine number reference page will enable you to approximately date the frame by that number.
MCHinson is offline   Reply With Quote
Old 12-06-2010, 12:20 PM   #6
Terry, NJ
Terry, NJ's Avatar
Were the Frames and engines numbered on the same day? Or at their respective assembly? My engine number is not the same as the chassis number, which is the same as the title. Engine switch? Or they never did match?
Terry
Old 12-06-2010, 12:24 PM   #7
MCHinson
MCHinson's Avatar
The engine number was stamped onto the frame after the engine was dropped into the frame, so your engine has been swapped sometime since the car was built.
Old 12-06-2010, 12:29 PM   #8
Mark Schwing
Engines were stamped with the engine number the day they were assembled. They might go directly to the vehicle assembly line at Dearborn or they might be shipped to one of the many other Ford assembly plants. When the engine was mated to a chassis, the frame was stamped with the engine number. Over the decades since engines were often replaced the two numbers no longer match. In most cases the number on the frame should be the serial number for title purposes. A rule of thumb is that engines went into a chassis within about three months or less of the engine manufacture.
Mark Schwing is offline   Reply With Quote
Old 12-06-2010, 02:51 PM   #9
Rbolt
THANKS,you guys ...Im learning
Old 12-06-2010, 05:22 PM   #10
Bob Johnson
Bob Johnson's Avatar
Default When was your engine number stamped
Click on link below to find out when a specific engine number was stamped.
LINK
Bob
Bob Johnson is offline   Reply With Quote
Old 12-06-2010, 06:07 PM   #11
Steve Plucker
You can also review my frame article on my website and come close to a time period of production.
Pluck
Old 12-08-2010, 04:18 PM   #12
Rbolt
Thanks everyone,i seem to have a sept 29 frame and a aug 29 engine
