I know that this was not the question, but I thought that I would add comparison photos of the 1935 and 1936 Ford Commercial Grilles. While they look similar, they are both different. The Grille in Grey Primer is off a 1936 Ford while the one in Red Primer is off a 1935 Ford. From the front, the difference is not immediately apparent, but from the side on shot, you can see that the sides are deeper on the 1936 Ford Grille than the 1935 Ford Grille. As Don stated, the same Grille fits the Pickup as well as the larger Trucks of the respective years.
