Old 06-18-2015, 05:42 PM   #1
1crosscut
1crosscut's Avatar
Default Re: Lube in a Syringe
Distributor uses a lighter oil. I use engine oil for it.
Steering box uses 600 wt. If it is a leaker try the Penrite lube in the steering box. Do not use grease in it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-18-2015, 05:59 PM   #2
jwaldrich
jwaldrich's Avatar
Where do you lube the distributor? It is probably obvious but I'm not seeing it.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
