Old 05-31-2015, 09:22 PM   #9
dicks41
Default Re: 1943 Ford truck
The transmission serial number is very easy to read and is: 99TF-544714. The frame number on the truck is the same. The Marmon Harrington number shows a chassis number: MM6-4-544714. The motor number on the Marmon Harrington also shows the 544714 number. The Sno Go tag also shows a motor number of 544714. I did find a truck just like this one with a serial number of 472367 at the Yankee Air Museum in Belville, Michigan. That particular truck is a 1942 but it does have a 1942 serial number. My information shows this 544714 serial number being after the last 1942 was built but prior to the first 1946 number. Also someone had asked if it's a right hand drive or not. It is a left hand drive but does have the glove box on the left side where the gauges would typically go.
dicks41 is offline   Reply With Quote
