Old 10-23-2014, 12:54 PM   #21
Bruce Lancaster
Default Re: Holley 94 ECG, rebuld but problem
Yes, a second complete venturi at the point of lowest pressure in the big venturi.
On these carbs, it is built into the removable nozzle bar, replacing the slanted type used about 1952--early Y blocks.
So far I haven't gathered much info on the later Ford E carbs...there are a lot of variants!
Old 10-23-2014, 02:28 PM   #22
Ross F-1
Ross F-1's Avatar
That's called an "annular discharge booster venturi", it was one of the big improvements compared to a 94.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-23-2014, 04:23 PM   #23
scicala
scicala's Avatar
Originally Posted by Kahuna View Post
Thank you, Bruce
I am unfamiliar with the 2 bbl carbs, but intimately familiar with the 4 bbl versions, that have a booster (maybe that's it?)
Yes, it's the same as a booster. A smaller venturi in the middle of the main venturi.
scicala is offline   Reply With Quote
Old 10-24-2014, 02:45 AM   #24
Cheaterpete
Ok, thanks a lot for your replies, I will try the 55 MJ asap"and let you know !
Thanks a lot again ;-)
Cheaterpete is offline   Reply With Quote
Old 10-31-2014, 07:48 AM   #25
Cheaterpete
Ok,
Here are the news
One of the carbs have 47 jets but the other one have 57... ;-(
Unofrtunately I do not have 57 jets but 55, I have tried, and big improvement!
The engine rev instantly and I still have little struggle at high rpm...
I now have ordered a O2 air fuel ratio controler, I will check with this gauge for better tuning, keep you posted
Old 10-31-2014, 02:46 PM   #26
shoe box Jack
I have the same carb. on my 260 cu. with 53 jets works real good. Jack
shoe box Jack is offline   Reply With Quote
Old 10-31-2014, 05:10 PM   #27
Ross F-1
Ross F-1's Avatar
I have sets of #54, #55, and #57. No need of them, if you want them let me know.
Old 11-01-2014, 12:59 PM   #28
Cheaterpete
Yes please!
