Old 10-03-2014, 09:51 AM   #1
Richardtx
Default Window adjustment
What is the position of the bottom window channel on the window glass ? How do you adjust the window when installing? Thanks
Richardtx is offline   Reply With Quote
Old 10-03-2014, 10:10 AM   #2
waterboychuck
waterboychuck's Avatar
Default Re: Window adjustment
What are you working on? Sometimes photos help too.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 10-03-2014, 10:13 AM   #3
mike42
mike42's Avatar
What year car ?
mike42 is offline   Reply With Quote
Old 10-03-2014, 11:04 AM   #4
Richardtx
Sorry for lack of information. It is a 50 Ford 2 door sedan. It is the front drivers side window.
Old 10-03-2014, 12:17 PM   #5
mike42
mike42's Avatar
Too "new" for me ! Sorry !
Old 10-03-2014, 12:24 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Generally it is positioned so that it is centered between the front and rear channels (doesn't hit either one ) Then the question is which way the arm track faces. The tilt adjustment is done by loosening the regulator mount screws and rotating as needed to get window to go up and down parallel to the front and rear tracks.
