Not a flathead, but hands on mechanic guys may get a kick out of this.
http://pixelbark.com/13045/how-the-d...bustion-engine Reminds me of the post a while back about the engine without a cam, valves driven by computer controlled actuators. Anyone know if more has come from that? |
This reminds me of the old rotary piston aircraft engines where the whole block and pistons spun around the crankshaft. Never understood how those worked but are fascinating to me as is this duke engine. It just doesn't' seem like it would produce the low end torque that a conventional engine does.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
Amazing, it doesn't have a spark plug for each cylinder!
Anyone know what the application is? Automobiles or marine or what? -VT/JeffH More on Wiki: http://en.wikipedia.org/wiki/Axial_engine Last edited by VeryTangled; 03-07-2014 at 11:11 AM. |
Vacuuming money out of investor's wallets, I would guess...
![]() I don't see any hope of the seals at the top of those cylinders holding out for a hundred thousand miles. I am impressed that they actually have a working prototype, that's more than many of the hundreds of alternative engines can claim.
'52 F-1, EAB flathead |
That's fascinating! The unique problems to overcome must keep them awake nights! This being the 3rd generation, they may be ready for a production decision by about the 10th generation!
Alan |
Lonnie |
Not a whole lot different than a swashplate A/C compressor either.
Which do you like better? Jack E/NJ
Would love to see the valvetrain.
Ignorance of the laws of physics does not mean they do not apply to you. |
There is none, it is piston-ported like a 2-stroke.
"Would love to see the valvetrain."
The gist I got out of it was no valvetrain. Looks like the pistons draw in fuel as they pass a cylinder with an intake port and expel the spent gases when they pass a cylinder with the exhaust port. |
Looks like the mechanical advantage of the power stroke of the pistons would be lessened on this engine versus a crankshaft engine, generating less torque. Too, it looks like it would require more torque on the compression stroke than a conventional engine.
Son, you will never blow an engine up in high gear. |
#13 |
Correct me if I'm wrong but isn't that basically the same setup as the swash-plate compressors used on modern day auto air conditioning? Sure looks like it to me.
#14 |
Yeah, I think so except the Duke plate is the stator while the block with the pistons is the rotor. Like Lou suggests, porting seems similar to the Wankel rotary.
Jack E/NJ |
#15 |
Sort of also using the sleeve valve engine concept in a different manner combined with modern rotary design
#16 |
Another variation of the radial engine as stated above. Wonder whatever happened to the cam engine being experiemented with in the late 80's. It was somewhat aproved by the FAA and then faded into obscurity. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
#17 |
#18 |
That looks like something flathead Ted would be involved with.
There is a diesel engine in the Motat museum that looks similar. Lawrie |
#19 |
The gnome & a few other rotaries at Glenn Curtiss museum, hport, ny
#20 |
That rotary wobble plate is going to have a lot of stress on it for the long haul since the power stroke won't be too equal with the opposite strokes. As was mentioned before, It's hard to figure how well the cylinder barrel will seal against the valve plate and not score the hell out of it. It's like an old Frigidaire compressor on steroids. If they used any more than 5-cylinders, it would be as big as a 55 gallon drum.
