Old 02-22-2014, 12:31 PM   #1
AnthonyG
AnthonyG's Avatar
Default Question, additional ground to engine
I know it's a subject beat to death but I have read recently that more grounding than just frame to battery is a good thing. In the article it didn't seem to talk about whether a ground strap or cable is a good Idea from the engine to the frame? Rational being it's gets a good ground closer to the starter motor?
Any thoughts?
Nomad
AnthonyG is online now   Reply With Quote
Old 02-22-2014, 01:15 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Question, additional ground to engine
Tony, there should be a ground strap from the passenger side head to the dash. The dash is the primary ground point from the battery. Further grounding to the frame is not a bad idea, but not required for anything but the lighting system.
Alan
ford38v8 is online now   Reply With Quote
Old 02-22-2014, 01:29 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
For the BEST operation of electrical components and systems in these old cars, these three factors concerning GROUNDING always apply.
1. You can never have TOO MANY grounds.
2. Your ground wires can never be TOO BIG.
3. Your ground connections can never be TOO CLEAN (or TOO TIGHT).
DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-22-2014, 01:30 PM   #4
jkeesey
jkeesey's Avatar
I always run a extra ground wire from the battery to the transmission. It makes a world of difference.
jkeesey is offline   Reply With Quote
Old 02-22-2014, 01:33 PM   #5
Bassman/NZ
Bassman/NZ's Avatar
DD
This should be law....
Bassman/NZ is offline   Reply With Quote
Old 02-22-2014, 03:46 PM   #6
dwick01
dwick01's Avatar
Great information V8COOPMAN! Thank you. I put this in my memory bank, which is a file I keep, only for this type of information.
dwick01 is offline   Reply With Quote
Old 02-23-2014, 03:08 PM   #7
AnthonyG
AnthonyG's Avatar
Great tips, thx guys I will definately archive in memory banks as said.
Nomad
Old 02-23-2014, 03:37 PM   #8
V12Bill
V12Bill's Avatar
My 46 and 48 Lincolns have a ground cable that goes from the + post to the battery box to the engine. My 39 pickup has a cable from the + post to the firewall and a second cable from the firewall to the engine. Apparently Henry knew about grounding his electrical systems and probably had similar grounds on other cars. It seems that some owners have a "better " way to do things and then run into trouble. On new restorations often ground bases get painted over and a good ground is lost.
V12Bill is offline   Reply With Quote
Old 02-24-2014, 09:10 AM   #9
36tbird
star washers
36tbird is offline   Reply With Quote
Old 02-24-2014, 09:14 AM   #10
sidevalve8ba
sidevalve8ba's Avatar
A good ground, or should I say, several good grounds are your friends.
sidevalve8ba is offline   Reply With Quote
