Go Back   The Ford Barn > The Archives > Model-T
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Ken in New Zealand
does anybody put anti freeze in the water of a model T over winter..if so what quantities?
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: Ken in New Zealand
Yes, many people do use antifreeze. Use the same ratio you use in your modern car - 50/50. 1925 Ford specifications show this capacity:
Total Capacity – 25 pints
Capacity Water Jackets and Hose – 5 quarts
These would be US capacities, not Imperial measure.
Antifreeze provides corrosion protection as well a freezing protection.
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
I start at 50/50 then add until good for -40c, I leave it in all year round without any problems.
Vic
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
I'm in Canada.
Old 01-01-1970, 12:00 AM   #5
Guest
Posts: n/a
Default Anti-Freeze
The other side of snti freeze is it raises the boiling point of the coolant. The 15 boiled constantly (breathe hard and you'd get tea time) until I did the 50/50 mix - now, it almost never steams up.
