Old 04-10-2013, 12:46 PM   #1
ole39
ole39's Avatar
Default 400jr
was just looking thru you tube and came across a vidio of vern tardel adjusting the lifters on a 400jr. he does .012 in, and .014 ex. i thought it was .018 and .018. thats what i set mine at. any major performance issues between the 2 settings?
ole39 is offline   Reply With Quote
Old 04-10-2013, 12:58 PM   #2
Pete
Default Re: 400jr
The wider settings may help the low end performance.
Your results may vary.
Old 04-10-2013, 02:19 PM   #3
36tbird
Default Re: 400jr
Pete, doesn't that make them a bit noisier, too? Mine set at .012 and .014 are a little noisy when cold.
36tbird is offline   Reply With Quote
Old 04-10-2013, 03:04 PM   #4
42merc
42merc's Avatar
Default Re: 400jr
I saw the same video, & I think Vern set them at .014 & .014. I Emailed him & his response was, " that it quiets them down somewhat ". I reset mine to .014 & they are quieter. Setting the valves tighter usually moves shifts the power band higher, but I'm not noticing any difference.
42merc is offline   Reply With Quote
Old 04-10-2013, 07:36 PM   #5
Pete
Default Re: 400jr
Yes.
Old 04-10-2013, 10:09 PM   #6
296 V8
Default Re: 400jr
Be sure and check it with a degree wheel …… the last two we checked were way off and got returned
296 V8 is offline   Reply With Quote
Old 04-10-2013, 10:18 PM   #7
Ol' Ron
Ol' Ron's Avatar
Default Re: 400jr
I like the 400jr as a race cam for short tracks, but they;re hard on the valve train and require some hefty spring pressure. One reason I changed to the L-100, sounds good runs great and #50 lbs will get you 5K. But if I was racing, that's another story.
