Old 08-12-2010, 05:53 AM   #1
dmaxweb
dmaxweb's Avatar
Default Brake & Clutch Pedal Shaft
What holds this in place and how is it removed?
dmaxweb is offline   Reply With Quote
Old 08-12-2010, 06:03 AM   #2
Wick
Wick's Avatar
Default Re: Brake & Clutch Pedal Shaft
The shaft is held on by a pin. Grind off the head and knock it out. Then you can drive the shaft out.
Wick
Wick is offline   Reply With Quote
Old 08-12-2010, 06:55 AM   #3
dmaxweb
dmaxweb's Avatar
Wick
Can you drive out the shaft through the bell housing inspection plate opening in the floorboard?
Old 08-13-2010, 10:10 AM   #4
MN Stumpjumper
MN Stumpjumper's Avatar
I'm pretty sure you need to have the bellhousing on the bench.
MN Stumpjumper is offline   Reply With Quote
Old 08-13-2010, 11:33 AM   #5
Don/WI
While it is doubtful that you could drive the shaft out through the inspection hole, it may be possible to fabricate a slide hammer to attach to the shaft on the outer end and get it out that way. I have not tried this method, but I would try this before disassembling the bell housing from the flywheel housing. You can always do that as a last resort. Good luck. Don/WI
Don/WI is offline   Reply With Quote
Old 08-13-2010, 11:53 AM   #6
1931 flamingo
1931 flamingo's Avatar
I would think on the bench as you have the throuwout brg fork to contend with also.
Paul in CT
Old 08-13-2010, 12:28 PM   #7
Wick
Wick's Avatar
Dmax ,I was thinking the bellhousing was out of the car when I responded.
Im just up the road from you in Mathews,ive got plenty of spare Bellhousings (7-10) if you ever need one.
Wick
Old 08-13-2010, 01:21 PM   #8
Rich in Tucson
Rich in Tucson's Avatar
Check the diameter of the new one if it is repro before pounding it in the hole; I had to turn several thou off of the last one I installed because it was oversized.
Rich in Tucson is offline   Reply With Quote
Old 08-13-2010, 01:26 PM   #9
Peter J
Peter J's Avatar
While on the subject of break/clutch shaft, my peddles are real sloppy. Could I get away with just replacing the bushings rather than taking out the shaft?
Thanks,
Pete
Peter J is offline   Reply With Quote
Old 08-13-2010, 01:46 PM   #10
J Franklin
J Franklin's Avatar
Take the pedals off and re-bush them, you can then check the shaft for wear.
Old 08-13-2010, 02:18 PM   #11
skip
Banned
Some additional info about the pedels, not the shaft. Control key held down and the + key to enlarge print.
skip is offline   Reply With Quote
Old 08-13-2010, 02:59 PM   #12
dmaxweb
dmaxweb's Avatar
I talked to Steve at Bert's and he said that I should be able to grind off the head of the pin and pull the shaft out with a vice-grips. He said he has done several 'on the car replacements' this way. I ordered the shaft and bushings. I am going to press in new busings and check how the pedals fit on the existing shaft. If they are still sloppy, time to tackle replacing the shaft.
Old 08-13-2010, 03:47 PM   #13
Vern The Man
Vern The Man's Avatar
Message is for Peter J. of Olympia, Wa.: Hi Peter, I saw your picture of the yellow coupe. I have a coupe the same color but I don't know what the name of that color is. I was told it was Bronson Yellow. I got some touch up paint of Bronson Yellow and it isn't even close. Please let me know. David in Marysville, Wa. (Vernaman)
Vern The Man is offline   Reply With Quote
Old 08-13-2010, 11:14 PM   #14
Peter J
Peter J's Avatar
Vern in Marysville, the color is called sunshine yellow. I found a match with my wife's acrilic paint set. It's not a Model A color.
Old 08-14-2010, 11:31 PM   #15
david801
david801's Avatar
I tried to replace the clutch/brake shaft by grinding off the head of the pin and trying to drive the pin through to the inside of the bell housing. The pin would not budge. I called around and found that only early (1928ish) bell housings will allow this. The newer bell housings use a tapered pin that MUST be driven out from the inside of the bell housing, so the bell housing must be off the vehicle and on the work bench. If you can accomplish this any other way please let me know.
david801 is offline   Reply With Quote
