Old 02-20-2013, 09:14 AM   #1
Mike
Mike's Avatar
Default Model TT truck
Good morning,
A friend is dropping off a 1919 TT Truck for me to work on, my problem is it will not fit into my garage. Does anyone make a stand that I can use with my car dollies if I remove the wheels ? Any help would be appreciated.
mike
Mike is offline   Reply With Quote
Old 02-20-2013, 11:38 AM   #2
trulyvintage
trulyvintage's Avatar
Lightbulb Re: Model TT truck
Originally Posted by Mike View Post
Good morning,
mike
Mike,
You can make wheel dollies that will support the frame
from casters - wood - bolts ....
You can try using commercial wheel dollies fastened to the
drums - not sure how good that would work.
Jim
trulyvintage is offline   Reply With Quote
Old 02-20-2013, 02:51 PM   #3
Mike
Mike's Avatar
Default Re: Model TT truck
Jim,
Ok thank you,
mike
Old 02-22-2013, 09:22 AM   #4
32forddump
32forddump's Avatar
Im just thinking outside the box, but couldnt you make 4 round discs out of 2 inch wood and put them on the axles.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
Old 02-22-2013, 11:54 AM   #5
yachtsmanbill
yachtsmanbill's Avatar
... but just big enough to have the oilpan clear the floor! ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 02-22-2013, 12:38 PM   #6
jkeesey
jkeesey's Avatar
Why don't you put the dollies on the rear drums and on the front axle?
jkeesey is offline   Reply With Quote
Old 03-01-2013, 08:50 PM   #7
Mike
Mike's Avatar
I let a little air out of the tires and it fit into garage, tight but it is in. I don't like jack stands and wheel dolly combo, I saw a close call when a Model A almost fell off the stand/dolly.
Mike
Old 03-04-2013, 11:04 AM   #8
Willie in Houston
Willie in Houston's Avatar
Mike, it would probably be a good idea to remember to drain some air out of the tires before you exit the garage when you are finish with the repairs.
Something like that is easy to forget. Maybe a note taped to the steering wheel?
Willie in Houston is offline   Reply With Quote
Old 03-05-2013, 08:54 AM   #9
Mike
Mike's Avatar
Thank you, yes I did just that, sticky notes everywhere
Old 03-06-2013, 12:38 AM   #10
dwollam
dwollam's Avatar
I have seen plywood disc "wheels" bolted on.
dwollam is offline   Reply With Quote
Old 03-07-2013, 11:26 AM   #11
brien
brien's Avatar
You may be able to use Hillman roller bearing skates. One under each brake drum:
http://www.hilmanrollers.com/prepackaged-kits-and-sets/
http://www.hilmanrollers.com/prepack...t-duty-series/
These are great for moving anythiing heavy and bulky. They are a bit pricey but once you have them you will love em!
brien is offline   Reply With Quote
