The Ford Barn
-   Model T (1909-1927) (https://www.fordbarn.com/forum/forumdisplay.php?f=2)
-   -   Model TT truck (https://www.fordbarn.com/forum/showthread.php?t=98195)
Mike 02-20-2013 09:14 AM
Model TT truck
Good morning,
A friend is dropping off a 1919 TT Truck for me to work on, my problem is it will not fit into my garage. Does anyone make a stand that I can use with my car dollies if I remove the wheels ? Any help would be appreciated.
mike
trulyvintage 02-20-2013 11:38 AM
Re: Model TT truck
Originally Posted by Mike (Post 596163)
Good morning,
mike
Mike,
You can make wheel dollies that will support the frame
from casters - wood - bolts ....
You can try using commercial wheel dollies fastened to the
drums - not sure how good that would work.
Jim
Mike 02-20-2013 02:51 PM
Re: Model TT truck
Jim,
Ok thank you,
mike
32forddump 02-22-2013 09:22 AM
Re: Model TT truck
Im just thinking outside the box, but couldnt you make 4 round discs out of 2 inch wood and put them on the axles.
yachtsmanbill 02-22-2013 11:54 AM
Re: Model TT truck
... but just big enough to have the oilpan clear the floor! ws
jkeesey 02-22-2013 12:38 PM
Re: Model TT truck
Why don't you put the dollies on the rear drums and on the front axle?
Mike 03-01-2013 08:50 PM
Re: Model TT truck
I let a little air out of the tires and it fit into garage, tight but it is in. I don't like jack stands and wheel dolly combo, I saw a close call when a Model A almost fell off the stand/dolly.
Mike
Willie in Houston 03-04-2013 11:04 AM
Re: Model TT truck
Mike, it would probably be a good idea to remember to drain some air out of the tires before you exit the garage when you are finish with the repairs.
Something like that is easy to forget. Maybe a note taped to the steering wheel?
Mike 03-05-2013 08:54 AM
Re: Model TT truck
Thank you, yes I did just that, sticky notes everywhere
dwollam 03-06-2013 12:38 AM
Re: Model TT truck
I have seen plywood disc "wheels" bolted on.
brien 03-07-2013 11:26 AM
Re: Model TT truck
You may be able to use Hillman roller bearing skates. One under each brake drum:
http://www.hilmanrollers.com/prepackaged-kits-and-sets/
http://www.hilmanrollers.com/prepack...t-duty-series/
http://www.hilmanrollers.com/wp-cont...4S-150x150.jpg
These are great for moving anythiing heavy and bulky. They are a bit pricey but once you have them you will love em!
