Old 08-29-2012, 03:00 PM   #1
Jake
Jake's Avatar
Thumbs down 32 grill shield ?
Does any distributors make the shield that goes in the bottom of the 32 grill ? Or does anybody have a pattern that they would be willing to share ? Thanks !
Jake is offline   Reply With Quote
Old 08-29-2012, 06:39 PM   #2
B-O-B
B-O-B's Avatar
Default Re: 32 grill shield ?
by shield do you mean the chin? That be the piece below the grille that hooks on the spreader bar. Brookville, Vintique just to name couple.
Most vendors have them
B-O-B is offline   Reply With Quote
Old 08-30-2012, 01:36 AM   #3
Jake
Jake's Avatar
NO I mean the splash shield that is ih the bottom of the grill shell .
Old 08-30-2012, 07:47 AM   #4
bills1020
Maybe i'm missing something, but isn't that shield part of the grille shell stamping ? If you are referring to at the bottom just behind the grille insert. Exactly what do you have?
bills1020 is offline   Reply With Quote
Old 08-30-2012, 08:05 AM   #5
HOTRODPRIMER
HOTRODPRIMER's Avatar
I assume,you are talking about a truck shell and you are referring to the metal piece that is made to the back side of the insert if it is a truck shell.
I suspect you will need to fabricate the replacement piece.
There is a lot of difference between a passenger car shell and a truck shell. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 08-31-2012, 01:26 AM   #6
Jake
Jake's Avatar
I have a pickup. I was not aware there was a difference. Thank you ! yes I am sure that one will have to be fabricated, that is why I am lookng for a pattern . Any help would be appreciated .
Old 09-01-2012, 01:20 PM   #7
raisinhel
raisinhel's Avatar
ALL FORD PARTS makes some kind of commerical grill repair panel. (33-34 - MAYBE 32 ALSO?)
i called them, they said they made one. i never got a catalog or saw a picture of what it is exactly.
those 32-34 commerical grills held debris down inside and its very common to see them rotted. if caught soon enough they are much easier to save before the front lower edge goes, then the grill bars come loose.
raisinhel is offline   Reply With Quote
