Old 04-23-2012, 05:34 PM   #1
Mart
Mart's Avatar
Default Question for 33 owners.
Is the radiator simply bolted rigidly to the frame with two bolts and nuts, or should there be springs involved??
Mart.
Old 04-23-2012, 06:30 PM   #2
DavidG
DavidG's Avatar
Default Re: Question for 33 owners.
Rubber pads, hex bolts with drilled shanks, springs, castle nuts, and cotter pins, with everything but the head of the hex bolts above the cross member.
Old 04-24-2012, 12:12 PM   #3
alchemy
alchemy's Avatar
Springs go ABOVE the radiator feet. I'm guessing they only helped when the chassis flexed, not to reduce any vibration from normal driving.
alchemy is offline   Reply With Quote
Old 04-24-2012, 01:22 PM   #4
bobbooth
bobbooth's Avatar
Good question Mart, I know about the springs and stuff but i have a 33 chassis and i take it a 34 radiator (it came with my car!!) the issue i have is that i have to space up the radiator from the frame to clear the crossmember and obviously that creates issues with the hood grille alignment are 33 different from the 34 radiators?
bobbooth is offline   Reply With Quote
Old 04-25-2012, 12:54 PM   #5
bobbooth
bobbooth's Avatar
btt
Old 04-25-2012, 03:28 PM   #6
David J
David J's Avatar
Does the bottom of your radiator look like this ? If not you need to find a different radiator . 33 & 34 take the same radiator . Only the grille brackets are different .
David J is offline   Reply With Quote
Old 04-25-2012, 03:49 PM   #7
Mart
Mart's Avatar
Bob, my radiator has been damaged by frost. The lower tank has ballooned and doesn't fit too well to the chassis. If your's looks like the picture and doesn't fit, it may be a bit out of shape like mine.
I can get some measurements and good photo's off mine if you like.
Mart.
Old 04-25-2012, 05:31 PM   #8
bobbooth
bobbooth's Avatar
Hmmm It dont look like that , when looked at from the front the edges of the radiator taper towards the outer framework could it be 34 pickup? I will try and grab a pic next time i'm down the unit..
