Old 05-31-2026, 06:03 PM   #21
Brian
Brian's Avatar
Default Re: 59ab 80 over cam bearing
With that block, you could make a billet cam with journals that ran directly in the block that incorporated incredible lift and duration. The stock journal size limits the amount of lift possible....Just dreaming.....
Old 05-31-2026, 09:50 PM   #22
Tim Ayers
Funny you say that, someone on Ebay is selling a master lobe for an Isky 505 cam. I believe Dale H. (Bored & Stroked) has one that Isky ground for him. Would need this type of block for that cam I'd assume.
Old 06-01-2026, 07:48 AM   #23
KiWinUS
KiWinUS's Avatar
Interesting. So it is not a 505 master that is for sale but a single lobe from a cam that has been ground to the 505 spec. As seller states cam is not a flathead.
KiWinUS is online now   Reply With Quote
