Old 05-31-2026, 12:41 PM   #1
kurt v
Default fuel gauge send unit
Are the fuel gauge sending unites up to 1955 compatible with the 1940 king sealy senders ?
kurt v is offline   Reply With Quote
Old 05-31-2026, 02:52 PM   #2
19Fordy
19Fordy's Avatar
Default Re: fuel gauge send unit
Kurt: According to Googler the answer is YES. The gas tank sending units are the same. Read about it here:
https://www.google.com/search?q=will...hrome&ie=UTF-8
Old 05-31-2026, 04:17 PM   #3
nelsb01
nelsb01's Avatar
Yes, they are --- all 6 volt.
All you will need to do is save your current extension for the unit. (where the connector is) and connect it to the new sending unit.
nelsb01 is offline   Reply With Quote
Old 05-31-2026, 04:40 PM   #4
rotorwrench
rotorwrench's Avatar
Ford used them up into the early 60s. They all work on the same principle if electric. Ford used instrument voltage regulators after 1956.
