Old 04-19-2026, 05:19 PM   #21
Tim Ayers
Default Re: battery disconnect switch
Originally Posted by glennpm View Post
I agree, mine is on the 12V negative ground side.
Same
Old 04-19-2026, 06:39 PM   #22
paul2748
paul2748's Avatar
Completely agree with you. I have had problems with two disconnects so now all I do is have a 1/2 inch wrench in the car to disconnect the battery. Never wore out a terminal either.
Originally Posted by cas3 View Post
I've never been a fan of those things. They quite often result in problems down the road a few years with bad connections in an un necessary gizmo. Just pull off the battery cable. If its clean as it should be, its an easy thing to deal with.
Those things are popular with the model A crowd as that wire harness is hot all the time. Your 47 has a fuse , no? Sorry, I am not familiar with post war stuff
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-20-2026, 11:43 AM   #23
corvette8n
corvette8n's Avatar
+1 on the Cole-Hersee I think I bought mine off of eBay, I made sure it was an older one made in the USA.
Old 04-21-2026, 12:20 PM   #24
51504bat
51504bat's Avatar
My 2 cents on which post to use for the battery disconnect. Think about when you disconnect the battery. You disconnect the ground first. That way you don't accidentally touch the hot cable to a ground source when disconnecting the hot cable with the ground still connected. JMO
Edit: but some sanctioning bodies specify that the hot side be used.
For NHRA compliance, use heavy-duty 1-gauge or 2-gauge welding cable for battery disconnect switches, especially with trunk-mounted batteries. The switch must be on the positive side, interrupting all electrical power, with the alternator wired to ensure the engine stops immediately when the switch is engaged
For Bonneville Land Speed Racing (SCTA rules), the battery disconnect switch must be installed on the positive side of the electrical system and act as a master cut-off for all electrical functions, including the alternator and ignition.
Old 04-21-2026, 01:48 PM   #25
tubman
tubman's Avatar
I don't really understand what you are saying in your first paragraph.
I do agree with the third and fourth paragraphs.
Old 04-21-2026, 04:46 PM   #26
51504bat
51504bat's Avatar
If you disconnect the ground first the hot post of the battery can lead to a spark if mistakenly touched to ground such as loosening the bolt on the cable end and momentarily touching the wrench to ground. Up to you which order you choose to use.
