Old 04-09-2026, 07:54 PM   #1
mercman from oz
mercman from oz's Avatar
Default Accessory 1955-1956 Ford Wire Wheel Cover
With these Accessory 1955-1956 Ford Wire Wheel Covers, how many Clips do they require?
Is it 4 or 5?
Old 04-09-2026, 09:10 PM   #2
mercman from oz
Default Re: Accessory 1955-1956 Ford Wire Wheel Cover
This is what the Accessory Wire Wheel Cover Retaining Clip looks like.
How many are required for each wheel - 4 or 5 ?
Old 04-09-2026, 10:23 PM   #3
miker98038
miker98038's Avatar
According to Casco, 5 per wheel
https://www.classictbird.com/Wire-Wh...ductinfo/1150/
miker98038 is offline   Reply With Quote
Old 04-09-2026, 11:49 PM   #4
mercman from oz
Thank you Mike - very enlightening. Regards Mercman <><
Old 04-10-2026, 01:15 AM   #5
mercman from oz
Installation Instructions, Compliments CASCO Thunderbird Specialists
Old 04-10-2026, 09:46 PM   #6
dmsfrr
dmsfrr's Avatar
This red '55, with a newer porthole top, has those oem clip style wheel covers. Of course 5 per wheel would be better but the 4 clips per wheel it currently has haven't been a problem in 9 years... even at freeway speeds.
I just got three spare used wire style wheel covers and they came with a bag full of spring clips. I might install a few clips next time the tires are replaced.
File Type: jpg IMG_20180623_120007025_HDR la vida llena.jpg (69.4 KB, 56 views)
Old 04-11-2026, 01:58 AM   #7
mercman from oz
1955 Ford Thunderbird with Accessory Wire Wheel Covers - dmsfrr
Old 04-11-2026, 03:06 AM   #8
mercman from oz
Australian 1956 Ford Customline with Accessory Wire Wheel Covers.
Apart from a Mainline Utility, this was the only 56 Ford V8 offered in Australia.
We never received any other body styles or the upmarket Fairlane models.
They all were powered by the 272 Y Block with Three Speed Manual Transmission.
This photo was taken over 40 years ago, and I haven't seen this car since.
The owner didn't like the inconvenience of pulling out these Wheel Covers to check the Tyre Pressure.
His solution was to drill a hole to allow the Valve Stems to protrude - problem solved!
However, after his first drive, he noticed that no valve Stem was protruding.
Result - Set of NOS Accessory Wire Wheel Covers destroyed.
Old 04-19-2026, 06:08 PM   #9
mercman from oz
1956 Ford Crown Victoria Skyliner with Accessory Wire Wheel Covers
