Old 03-27-2026, 12:28 AM   #1
Lawrie
Lawrie's Avatar
Default nice to work on 34
I have been working on a friends A for some time, finished it the other day,/so decided to remove the generator on the 34 to fit a new front bearings per the last V8 times mag article, the 34 will do a few miles in the next two months so this was a nice clean easy job.
So, a thank you to the guy who wrote the article.
Lawrie
Old 03-27-2026, 06:37 AM   #2
rockfla
rockfla's Avatar
Default Re: nice to work on 34
That would be Steve Blanchard ndnchf here on the Fordbarn. His work is second to NONE.....DavidG/Kube level stuff!!!!!
Old 03-27-2026, 10:44 AM   #3
petehoovie
petehoovie's Avatar
Old 03-27-2026, 02:43 PM   #4
Lawrie
Lawrie's Avatar
it was such an easy job, my 33 has the stock setup in, it seems fine ,has done lots of miles, but I may take it out and have a look just to be sure
Lawrie
Old 03-28-2026, 07:46 PM   #5
koates
Hi Lawrie. I think I would prefer to still have the tapered roller double bearing set up still in the front of the generator which are in there for a reason to handle the fan thrust. I dont rely on the oil lubrication but pack the bearings with front disk brake high temp grease after first inspecting the rollers and race for wear and washing them out . People dont like buying new ones because of the cost..Have to be very particular about the adjustment just like the front wheel bearings. Correct belt adjustment is very important too. Regards, Kevin.
koates is offline   Reply With Quote
Old 03-29-2026, 11:09 PM   #6
Lawrie
Lawrie's Avatar
Kevin, I did the 33 today with the same mod, it had the original little tapered rollers in that were ok but ,lots of oil inside the generator, self inflicted of corse.
So will try the modern angular contact bearings for a while.
how's things, we are heading off in the 34 in a couple of weeks to victor harbour, fuel should be sorted I hope by then,
Lawrie
Old 03-30-2026, 06:30 AM   #7
Terry,OH
Terry,OH's Avatar
Charlie Schwindler originally published an article for the modification in the V8 Times many years ago. The modification has changed since but remains the same basic idea.
Old 03-30-2026, 09:47 AM   #8
Kens 36
Kens 36's Avatar
Terry,
Correct. Charlie Schwendler (note spelling) is the person who originally developed and wrote about this technique. His article was on page 18 of the Jan-Feb 2004 V-8 Times. I can't post a PDF here but will be glad to share the article with anyone who would like to read it. Just send me a private message with your email address.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
