Old 03-04-2026, 02:31 PM   #1
Vanspeed
Vanspeed's Avatar
Default 35-37 back of cab bracing help needed
Does anybody have a really nice cab that has had no damage to the vertical braces that go from the window opening to the floor? I had to remove them to repair the bottoms and actually took one from another cab that was in better shape. Are these flat or is there a slight curve in them? I see at the bottom there is a little curve but one from there up is flat and the other is slightly curved. Which one is correct? Any help appreciated.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 03-04-2026, 03:53 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 35-37 back of cab bracing help needed
Old 03-05-2026, 11:50 AM   #3
art ebeling
art ebeling's Avatar
Mine look straight except at the bottom to attach to the floor. They only attach at the top and at the bottom. The back of the cab is not attached to the brace and it does not appear to conform to the the back of the cab. Art
art ebeling is offline   Reply With Quote
Old 03-05-2026, 12:04 PM   #4
petehoovie
petehoovie's Avatar
Old 03-05-2026, 01:00 PM   #5
Vanspeed
Vanspeed's Avatar
Thank you for the pictures, I appreciate it.
Old 03-06-2026, 10:12 AM   #6
37 truck
Mine had a material between the braces and the cab. Kind of like horsehair for damping.
37 truck is offline   Reply With Quote
Old 03-06-2026, 05:31 PM   #7
Vanspeed
Vanspeed's Avatar
That was going to be my next question. There was some material between the roof ribs but nothing on these as they were both broke due to getting hit pretty hard in the back of the cab. I wonder what would be a good replacement material.
Old 03-07-2026, 07:41 AM   #8
nelsb01
nelsb01's Avatar
Weather stripping sold at a hardware store. Look for the grey felt style. (with or without sticky adhesive). It comes in different widths; find the size you need. Should be about 1/8 to 3/36 inches thick.
You can also use this for the seal on your floorboards.
nelsb01 is offline   Reply With Quote
Old 03-08-2026, 02:12 PM   #9
Model51
Model51's Avatar
Attached is an image from the 50-813152 Ford Engineering Drawing from 1935 showing the part you are asking about. It's straight except for a short section on the bottom. Hopefully you can figure it out as it's a bit dark and is just a small section of a very large drawing.
This support has anti-rattle material between it and the back of the cab and so does the roof support rib(s). I used Dyna-Mat to insulate my cab and slid this material into the gaps and it works just fine.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 03-08-2026, 04:32 PM   #10
petehoovie
petehoovie's Avatar
