Old 02-22-2026, 09:18 PM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default 8ba block
Hi guys.. will a crab distributor work on a 8ba engine?
Fatheads4ever is offline   Reply With Quote
Old 02-22-2026, 09:30 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 8ba block
It will but not without a lot of work and some changes.
Old 02-22-2026, 09:54 PM   #3
Fatheads4ever
I'm thinking the timing cover and the gears from my c59a would need to swapped over
Old 02-22-2026, 10:03 PM   #4
big deuce
big deuce's Avatar
Different cam... means teardown.
big deuce is offline   Reply With Quote
Old 02-23-2026, 08:30 PM   #5
mcgarrett
Not sure I understand - what is to be gained by making this change?
Old 02-23-2026, 09:57 PM   #6
19Fordy
19Fordy's Avatar
Here's a photo of an 8BA with crab distributor in my friend's 40 built by Mark Kirby (RIP) many years ago. It allowed for the installation of A/C compressor. I recall the cam had to be changed.
Old 02-23-2026, 10:00 PM   #7
petehoovie
petehoovie's Avatar
Old 02-23-2026, 10:01 PM   #8
19Fordy
19Fordy's Avatar
Thanks very much Pete.
Old 02-24-2026, 06:52 PM   #9
Fatheads4ever
That engine looks like a earlier motor withe the water outlets in the center of the heads.
Old 02-24-2026, 07:02 PM   #10
Fatheads4ever
I can get a 8ba short block without the distributor.
But I have a c59a engine complete.
I also think the crab with its HT cabling looks far more athletic in my opinion.. just saying.
Old 02-24-2026, 07:15 PM   #11
joel
joel's Avatar
Does the c59A run? Does it need rebuilt? Why don't you want to use it?
joel is offline   Reply With Quote
Old 02-24-2026, 08:28 PM   #12
Fatheads4ever
Yes the c59a runs fine despite a crack between a intake valve seat and the bore in cylinder 7.
Old 02-25-2026, 08:59 AM   #13
19Fordy
19Fordy's Avatar
It's a later block with early style heads like this one.
Old 02-25-2026, 12:04 PM   #14
petehoovie
petehoovie's Avatar
Old 02-25-2026, 12:56 PM   #15
19Fordy
19Fordy's Avatar
Thanks Pete. Your enlargements always look so good.
