Old 02-15-2026, 06:59 PM   #1
[email protected]
johnr9q@yahoo.com's Avatar
Default Can't identify this part
It is conical shaped. It is either part of the steering box or the horn assembly in the steering wheel.
1931 Model A Ford Slant Window
johnr9q@yahoo.com is offline   Reply With Quote
Old 02-15-2026, 07:09 PM   #2
Mark A Johnson
Default Re: Can't identify this part
Its a shim for the radius ball.
Mark A Johnson is offline   Reply With Quote
Old 02-15-2026, 07:12 PM   #3
Gary WA
Gary WA's Avatar
looks like a radius ball fix washer?
www.whidbeymodelaclub.com
Old 02-15-2026, 07:24 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Radius ball shim washer.
Old 02-15-2026, 07:26 PM   #5
Ruth
Looks like the shim to bandaid a worn out radius ball.
Ruth
Old 02-15-2026, 07:32 PM   #6
The Master Cylinder
The Master Cylinder's Avatar
Either a Oil seal retainer for a two tooth steering box or a fix for a worn radius arm ball.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 02-15-2026, 08:04 PM   #7
[email protected]
It's not for the radius ball. As you can see in the picture it is not round but has a little curve to it. The Master Cylinder: As you say, it must be an Oil seal retainer for a two tooth steering box. Where does that go?
Old 02-15-2026, 10:52 PM   #8
WTSHNN
WTSHNN's Avatar
Is it this?
https://www.snydersantiqueauto.com/p...7837&cat=41748
or this?
https://www.snydersantiqueauto.com/p...7770&cat=41738
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
