Old 01-27-2026, 08:20 PM   #1
jetrod
Default Engine wear
Barners, I am going to check a used engine tomorrow. Question after I do a compression test can I manually, thru the spark plug hole, feel for a cylinder ridge JR
jetrod is offline   Reply With Quote
Old 01-27-2026, 08:35 PM   #2
The Art Doctor
The Art Doctor's Avatar
Default Re: Engine wear
No not really, the spark plug hole is over the valves not the piston. An inspection camera on the end of a snake might work for a visual.
The Art Doctor is offline   Reply With Quote
Old 01-27-2026, 09:09 PM   #3
ford38v8
ford38v8's Avatar
You should know that a compression check on a cold engine can be unreliable. Thoroughly warm it up to full operating temp if possible. On the other hand, low numbers from a cold engine can translate to an excellent bargaining chip for you.
Alan
Old 01-28-2026, 09:19 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
Every used engine is a gamble - no matter what the person says, even if they are a friend. What year/type of engine and what sort of price? Also, is there any guarantee as to the condition? Frankly, every used engine I've ever bought, I've ended up rebuilding in a year or two.
Old 01-28-2026, 02:01 PM   #5
Ggmac
Ask if you can pull the intake at minimum and head gaskets are next . Offer new gaskets and installed may help . Its definitely worth the $75 to look inside . If up north ( freeze areas ) check for cracks or water , rust where it should not be .
Old 01-30-2026, 11:51 AM   #6
51shoeboxer
Yes, my endoscope has become indispensable.
51shoeboxer is offline   Reply With Quote
