Old 01-10-2026, 04:15 PM   #1
V8guy
V8guy's Avatar
Default Sun Distributor Machine Strobe
I have a late 40s early 50s Sun Dist machine that I purchased in the 1970s the strobe is getting weak and will only flash at higher RPMs, every thing else works as it should. Suggestions for repair.
Thanks Mike
V8guy is offline   Reply With Quote
Old 01-10-2026, 04:53 PM   #2
rockfla
rockfla's Avatar
Default Re: Sun Distributor Machine Strobe
Paramount in Michigan has an LED upgrade kit of like the 404, 504 Sun Machines, I upgraded my 504.
Old 01-10-2026, 04:53 PM   #3
Bob C
I have a Sun 680 that the strobe was not working and I got a capacitor and diode kit from Paramount and that fixed it.
http://paramountd.com/index.html
Old 01-10-2026, 07:35 PM   #4
hotcoupe
hotcoupe's Avatar
suggest that you take a look at the u-tube video by "Opera", very interesting modifications. Dead nuts accurate.l've posted this info before, no one seemed interested, here's the link to one of his videos, https://youtu.be/W7rXdZVCz1Q
Tom
hotcoupe is offline   Reply With Quote
Old 01-10-2026, 09:52 PM   #5
3twinridges
3twinridges's Avatar
Paramount had the parts to get mine working. A good distributor machine is so nice to dial in the points and check vacuum advance/adjust advance springs.
JB
3twinridges is offline   Reply With Quote
Old 01-11-2026, 02:36 PM   #6
deuce_roadster
deuce_roadster's Avatar
No thanks. My Sun machine works perfectly like it is.
