The Ford Barn
-   -   Sun Distributor Machine Strobe (https://www.fordbarn.com/forum/showthread.php?t=355033)
V8guy 01-10-2026 04:15 PM
I have a late 40s early 50s Sun Dist machine that I purchased in the 1970s the strobe is getting weak and will only flash at higher RPMs, every thing else works as it should. Suggestions for repair.
Thanks Mike
rockfla 01-10-2026 04:53 PM
Re: Sun Distributor Machine Strobe
Paramount in Michigan has an LED upgrade kit of like the 404, 504 Sun Machines, I upgraded my 504.
Bob C 01-10-2026 04:53 PM
I have a Sun 680 that the strobe was not working and I got a capacitor and diode kit from Paramount and that fixed it.
http://paramountd.com/index.html
hotcoupe 01-10-2026 07:35 PM
suggest that you take a look at the u-tube video by "Opera", very interesting modifications. Dead nuts accurate.l've posted this info before, no one seemed interested, here's the link to one of his videos, https://youtu.be/W7rXdZVCz1Q
Tom
3twinridges 01-10-2026 09:52 PM
Paramount had the parts to get mine working. A good distributor machine is so nice to dial in the points and check vacuum advance/adjust advance springs.
JB
deuce_roadster 01-11-2026 02:36 PM
No thanks. My Sun machine works perfectly like it is.
