Old 12-16-2025, 12:48 AM   #1
Bigdipper
Default Plumbing a single master cylinder
Can anyone send me a plumbing diagram for a model A hydraulic brake conversion. I am trying to figure out how to plumb my single master cylinder with a 10 lb rpv from the outlet of the master cylinder to the connection of the front and rear brake lines and a low pressure brake light switch. From what I have researched the switch needs to be plumbed before the rpv so it will work correctly. Anyone have a picture or diagram of this plumbing would be greatly appreciated.
Bigdipper is offline   Reply With Quote
Old 12-16-2025, 06:52 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Plumbing a single master cylinder
Plumb the switch first out of the master cylinder, then the rpv, BUT I would strongly suggest installing a mechanical brake light switch on the pedal bracket (assuming chassis mounted pedals) vs the crappy hydraulic switches now available. A quality weather resistant mechanical, like the Ron Francis SW42 I use on several cars, can handle high current halogen bulbs and allows sensitivity adjustment a pressure switch cannot.
Old 12-16-2025, 10:07 AM   #3
glennpm
glennpm's Avatar
Please tell us what you are using for the master cylinder. If the early Ford type, there is residual check valve already in it.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
