Old 10-11-2025, 08:36 AM   #1
Burt Lake Barn
Burt Lake Barn's Avatar
Default Holley 94 carburetor spacer
I'm looking for a good source for Ford Flathead carburetor spacers. My 8BA sits with a slight tilt and I would like to get my carbs sitting correctly without the slight lean. I'm running 3 Holly 94's on an Edelbrock intake. Thanks.
Burt Lake Barn is offline   Reply With Quote
Old 10-11-2025, 11:43 AM   #2
Drbrown
Drbrown's Avatar
Default Re: Holley 94 carburetor spacer
I use to think my carb was getting overheated from the intake manifold and bought a spacer to deter heat transfer to carb body. However its a uniform thickness. Its a plastic based material and I suppose one could have a machine shop mill it down to provide a level surface - one for each carb. Might have to do some carb linkage adjustments.
Drbrown is offline   Reply With Quote
Old 10-11-2025, 01:46 PM   #3
Burt Lake Barn
Thanks, I thought someone told me that somewhere they make them with an angled top edge that you could get in different degrees based on your situation. I'll keep checking back here in case that outfit exists somewhere. Thanks for your reply.
Old 10-12-2025, 06:58 AM   #4
The Art Doctor
The Art Doctor's Avatar
Here you go
https://www.ebay.com/itm/236276874329
The Art Doctor is online now   Reply With Quote
Old 10-12-2025, 12:59 PM   #5
petehoovie
petehoovie's Avatar
Originally Posted by The Art Doctor View Post
See also > https://www.ebay.com/sch/i.html?_nkw...sid=m570.l1313
Old 10-12-2025, 08:42 PM   #6
ford38v8
ford38v8's Avatar
The seller can also supply angles opposite of the one pictured.
Alan
