I’m hoping one of you electrical gurus can give some advice on how to set up a sound system on the Tonner. It has a Whitney 6 Volt 40 Amp Positive Ground Alternator that I would like to use to drive a 110 Volt AC amplifier to send sound to two 50 Watt Bose speakers mounted on the truck. If using the 6 V alternator isn’t feasible any suggestions to accomplish the same result will be appreciated. Providing some patriotic music during parade events this coming year is something that I think parade watchers might appreciate. Thanks.
Les Williams |
Mount a 12v (si 10) alternator on the differential and mount a battery on the frame rail back there then you can run all the 12v you need.
I am building a 1939 1 ton express |
Thanks Yobbo. That's one helluva ingenious solution, but it involves too much surgery on the Tonner at this point. Just out of curiosity how does the driveshaft speed affect the alternator performance especially when in low gear ?
There are 6 to 12 volt inverters, but not sure how many amps they make. Look em up on ebay
#8 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
