Super Moderator
'36 Ford. Want to install a NOS return spring to the brake mechanism at the X member.
Yes, I have the correct spring, yes, I know where it attaches. How do I stretch it to get it over the pin? Yikes...
Super Moderator
Got it! Made a small and crude puller of sorts. The NOS spring makes a huge difference.
A pictures worth a thousand words.
Don't make any marks on the spring with plyers or eventually the spring will break in that spot, that goes for any spring, especially brake springs.
Super Moderator
I didn't.
Super Moderator
I will add that finding the correct spring was very difficult.
Back in the day, there had to be a 'guy' that could use a hook tool to pull on it and get it in place.
I ended up using a come-along and a strong piece of wire to 'convince' the spring into place. Then cut the strong piece of wire. Kube is right -- makes a difference in the brakes. |
I just use a bit of 1/16" welding wire, bend it into a U, feed it through the hole at back of Xmember, put hook of the spring into the U shape, use a pair of vice grips on the two ends of the wire as a decent handhold, and pull the spring back and into place.
I have used a bent piece of coat hanger pulled by a ratchet strap connected to the I-beam.
Super Moderator
I have to wonder how Ford did this rapidly on a daily basis.
Where can I find one of these, nothing shows up on the interweb? Failing that, does anyone know what the spring rate (i.e. pounds/inch) is for improvising something? My current spring is only 80% complete.
'35 5 Window Deluxe Coupe w/radio- wife's uncle purchased new |
#12 | |
Super Moderator
I don't know the rate but it requires a LOT of pull.
