Old 06-14-2025, 03:43 PM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Mercury Pressure Plate Bolts
Who has them? The Ford bolts are different ….
Third Gen does not list them - if for nothing else, what is the thread size?
Thanks,
TomT
TomT/Williamsburg is offline   Reply With Quote
Old 06-14-2025, 03:57 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Mercury Pressure Plate Bolts
Tom: Here ya go:
https://www.ebay.com/itm/12626397331...Bk9SR_TWy4PuZQ
http://vanpeltsales.com/FH_web/flath...ecs49-53V8.htm
Old 06-14-2025, 04:10 PM   #3
TomT/Williamsburg
Thanks! Got 'em!
Old 06-14-2025, 07:06 PM   #4
leon bee
^^^ Nicely done.
leon bee is offline   Reply With Quote
Old 06-15-2025, 11:32 AM   #5
rotorwrench
rotorwrench's Avatar
Mid century Mercury cars that use the Borg & Beck clutch are larger diameter than the Ford bolts. The earlier post war Ford and Mercury are the same diameter. The later Mercury stuff was just a bit heavier duty. The original part number for the 3/8"-16 X 3/4" is 355538-S used from 1949 thru 1953. A lot of folks use ARP bolts for replacements. The originals are not common but GM used a lot of 3/8"-16 bolts.
Old 06-15-2025, 03:29 PM   #6
TomT/Williamsburg
Thank you!
