Old 05-29-2025, 01:54 PM   #1
redmodelt
redmodelt's Avatar
Default 1925 with Chevrolet overhead conversion
End of May red eye candy. Poured machined my own mains. Will be using timer and coils. Not a high compression setup, just a bit more over stock. The coil box will/is mounted on the bracket in the last photo like the 1926/27 did.
Old 05-29-2025, 10:23 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 1925 with Chevrolet overhead conversion
What HP will you expect? It does look real nice.
Old 05-30-2025, 11:13 AM   #3
gz
gz's Avatar
Great engine. Zoom zoom!!
gz is offline   Reply With Quote
Old 05-30-2025, 12:05 PM   #4
rotorwrench
rotorwrench's Avatar
Mods like this make me wonder how a person deals with piston clearance and clearance volume. The adapter plate has to be pretty thick to get a good bolt up. Are pop up pistons used?
Old 05-31-2025, 07:04 PM   #5
redmodelt
redmodelt's Avatar
HP no clue. How thick would depend on material used to make the plate. I used aluminum at about 1" thick. This one is what amounts to two offset holes made with only using a drill press and burr. Others used a more wedged shape. As long as there is clearance for the valves to come down and popup for top of pistons you can get a lot of squish out of the adapter. I got the water outlet from Gene French years ago.
Just standard pistons. The 1928 head does have larger valves.
Old 06-01-2025, 12:34 PM   #6
A bones
A bones's Avatar
Super soup job.
You really did good there.
Any extra power is always welcome
Thanks
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 06-02-2025, 06:51 PM   #7
mercman from oz
mercman from oz's Avatar
Very impressive
Old 06-03-2025, 12:20 PM   #8
redmodelt
redmodelt's Avatar
Thank you!
You may not be able to view this until May 4th but here is a link to it running.
https://www.youtube.com/watch?v=udkEFezOZ2s
Old 06-05-2025, 07:37 PM   #9
Dads37PU
That's awesome, sounds good too!
Good job Mark!
Dads37PU is offline   Reply With Quote
